MIG ground cable question.
Bent
Only Marble Sharp
My welder (Millermatic 252; 30A - 300A) has a 15' wire feed cable on the gun but only a 10' ground cable. I'm wanting to go to 15' on the ground as well. The current ground cable is 3 gauge. Should I bump it up to #2 for the added length?
Is there a table of specs that shows how much amperage is going through that cable when you have the machine working at max capacity?
It would be nice to have actual numbers, but even without them I doubt you need to upsize the cable for an extra 5'. If you wanted to add 50' to it that might be another matter, but as long as the amperage drawn is not being changed I don't think you need to worry about it. Cable sizes generally correspond to amperage and don't change much until you get to substantial lengths. Unless you are already right at the edge I can't see how going from 10' to 15' is going to make a noticeable difference.
On a related tangent, have you looked at the MagSwitch ground connectors? Where were those things 20 years ago? Or why didn't anyone tell me about them earlier?
You should be fine but it might give you better control with larger cable.
