Tips on doing front axle ujoints?
Kejtar
PostMaster General
Depending on time, I am planning to dig into them tomorrow..... any tips? potential problems??? Anything else I migt want to do while there??
Thanks
http://www.stu-offroad.com/misc/axle-1.htm
then
http://www.stu-offroad.com/misc/u-joint-1.htm
other stuff to do... change the front diff oil maybe? while you have the diff cover off and the shafts out, pull the carrier and replace the seals if they're leaking (if they're not, be very careful R&R-ing the axle shafts so as to not start a leak!)
if you need new brake pads, now's a good time to take care of them. lube the balljoints & tie rod ends.
not much else i can think of :)
