Old October 2nd, 2018, 20:54
trippled trippled is offline
Re: Projext "V8 XJ" Build
I ran into this on mine recently. Little different but I but new springs on mine, the way I had my shackles it sat crazy tall in the back. I eyeballed some new mounts, burned em on all looked ok, little more angle than I wanted but not terrible. After a few runs and the springs settled they were doing like yours. I didn't want to cut new mounts out and cut off the old ones so I cut the shackles in half and spliced in a 1in long piece of 2x2 tube. Plated em up and it fixed the angle. But now it sits high in the back again. It wasn't the best option but it was quick and it works.
Old October 2nd, 2018, 23:59
PhotoJared's Avatar
PhotoJared PhotoJared is offline
Originally Posted by Exxon Valdez Jeep View Post
Can the no lift brackets be flipped around, reversed?
No I actually need the lift back that regular shackle boxes would supply. I'll probably get in contact with Brian at HD Offroad (Brian Right??)
Old October 3rd, 2018, 18:58
GordoSmasho's Avatar
GordoSmasho GordoSmasho is offline
Sierra Chapter Treasurer
I would move the frame shackle mount location back one more. I know it looks like you will loose lift. But i bet it will get the shackle angle back closer where it needs to be. I have the same relocation kit with longer than stock leafs. I used the boostwerks shackle to gain back a bit if lift. But the nolift boxes helped a ton with rear body roll. Not sure why but body roll was way better with them than the previous setup with the drop boxes and same leafs and shorter shackles.
Old October 4th, 2018, 01:56
PhotoJared's Avatar
I actually tried. The nut for the shackle wonít fit. Thereís a Bend right behind that hole and the nit wonít actually sit flush. Iíll probably just fab up something simple and bolt in.
Old October 4th, 2018, 02:01
PhotoJared's Avatar
Ok so hereís the ďfew hour crossmemberĒ. I actually like the way it turned out and really donít see a need to change it. Itís just a 27Ē piece of 2x6 3/16 wall. Cut some 45ís in it so we can actuallly get to the bolts:
Drilled a couple of new holes:
And mounted it up! Iíll try to grab a daytime picture tomorrow. I drilled a couple of more holes in the middle for the transmission mount and weíre in business:
Old October 4th, 2018, 02:02
PhotoJared's Avatar
The cuts came out pretty clean. This was the first time using my Evolution Rage cold cut saw. I will say though. It flings a TON of hot metal everywhere.
Old October 4th, 2018, 02:05
PhotoJared's Avatar
Oh and a braided line broke on my today. Went to test the fuel system and on the back frame rail I had a massive fuel leak. When I disconnected the rear brake hose I just have smashed the braided line or something. I don’t have time to replace the entire hose so I’m just going to splice in a repaired line and it should work perfectly.
Old October 5th, 2018, 18:33
You have to notch that original shackle mount back before you install the box. Part of the install instructions i think. I ended up using that same hole.
Old October 5th, 2018, 18:36
Crossmember looks good. Very similar to how mine turned out when i swapped in my atlas.
Old October 5th, 2018, 22:48
PhotoJared's Avatar
I honestly donít think that will give me enough. Iíll try it eventually. I might just have to dab some drop brackets that bolt into the no lifts.
Yea itís super simple. But itíll work just fine.
Old October 5th, 2018, 22:49
PhotoJared's Avatar
It’s out of the garage for the first time in 2 years!
Old October 6th, 2018, 05:14
cleenrob's Avatar
cleenrob cleenrob is offline
nice!
Old October 6th, 2018, 08:51
R6TeXJ's Avatar
R6TeXJ R6TeXJ is offline
congrats man!
Old October 14th, 2018, 07:43
PhotoJared's Avatar
We made it to Dallas! It was a long couple of days but we’ve landed. The Jeep is probably going to sit for a few months without any work. We’re in a rental house and we’re just waiting on our Vegas home to close. Once it does we’ll buy our own home and then work cannstart again
BUILD: My 1987 "Wagoneer" XJ Limited Crist Clapper OEM Tech Discussion 294 April 27th, 2018 18:42
Troy's "I need to quit working on my wife's Jeep" build troy5118 Midwest Chapter 64 November 28th, 2017 22:09
my "wannabe jeepspeed" grand cherokee build grandrunner JeepSpeed, Prerunner and Competition Tech Forum 157 July 1st, 2014 03:48
Project Jericho Stroker build. "The Craigslist Homerun" jwittlock Modified Tech Discussion 36 December 29th, 2012 02:14
98 XJ Sport, lifted "Project Impound Build" XJ&CHZ4ME MWC For Sale/Wanted Forum 5 May 20th, 2011 12:19
