Well, like was said, not much to add.
FWIW, Im a land rover tech at a Land Rover dealer. They Suck. Granted, I only see the broken ones, but I still know they suck. I could go on forever, but ill keep it simple. This is all for just the discoveries... The engines frequently need the WHOLE thing re-sealed. Theyre all aluminum and they leak oil from the oil pan, vc, heads, timing cover...u get the point. Front axle seals leak. Brakes only last a few thousand miles and cost about $1500 to get new pads and rotors - at the dealer, which is rediculous. ABS modules love to take a crap, whcih is over $1000. Window regulators fail, Air compressors fail if u have air suspension, air injection pumps fail, ac modules fail O2 sensors fail.... etc. The engine is sooo weak and gets about 12 mpg. The TC in the later ones don't have a locking center diff, so if 1 tire looses traction, u go nowhere! It rides pretty loudly too.
And to top it off, they are COMPLETELY LAST on JD Powers and Associates initial quality ratings...look it up.
On a good note: they look cool, have coil sprung radius arms front and rear with solid axles, and are actually pretty good offroad. If u ever plan to go offroad I'd get a series I, or an early series II. The later series IIs are for soccer moms only. I hear you can relatively easily change every single body panel, including the rear quarters if need be also.
