phred
- Corvallis, Oregon
Couldn't find any other discussion of this problem so here goes.
The release button on the tranny shifter won't go in when the ignition is in the Start or Run position. Only time the button will go in is when the key is in what I think is the Accessory position, the first click past Locked.
Sooo, to start it up I have to put the key in the ACC position, move the shifter to Neutral, then crank it up. If I start with the shifter in the park position, the button will not go in and I have a nicely running but immobile Jeep.
Also noticed that the shifter will move between N and D without pushing the button in at all. Will also move from R to N without the button, but not the other way around. Don't know if that is related or not or if it is normal behavior.
The starting interlock problem started spontaneously the other day - any clues about the fix would be appreciated.
Thanks.
Allen in sunny Corvallis, OR (hasn't rained here in two weeks - spooky).
1990 Cherokee, 2WD 159,000 miles. stock.
Thanks.
