Parking Lamp Fuse Keeps Blowing, Where To Look First?
Mich88XJ
So last night my gauge lights went out, turns out the fuse for the parking lights blew. Tossed a new one in, started the Jeep, turned on parking lights, still was okay (IDK if the lights came on) as soon as I turned on headlights it blew. Headlights are working. Turned Jeep off, put in a 15A fuse, as soon as I turned on the parking lights it blew. Any idea where to start looking first?
You can unplug all the lights on the back end behind the spare tire.
That should tell you which end to start looking.
Disconnected the trailer hitch wiring, and it didn't do anything, gotta figure out a way to the store to get more fuses to keep checking, the flex joint is fine, no wires worn through or anything like that. Thanks for the help!
It did do something, know you know the troubles in the front.
Look for burnt wires on the light switch.
There is a joint under the carpet on the driver's side near the front. If you unplug that and it STILL blows the fuse, then the headlight switch is the likely cause. PS: A circuit breaker may be a wise investment!
