blistovmhz
- Vancouver, BC
Found another thread from 2011 discussing throwing in a 98 4.0L into a 00 XJ, but it was never resolved I guess, and I'm now in the same boat. Figure a new thread that will see a final resolution is better than reviving a 5yo thread.
Girl didn't check the oil in her civic. I hate working on civics. Bought her a Jeep instead.
Found a suspiciously sweet looking 00 XJ and should've know better, because an XJ that LOOKS good, is always bad. Suspension was obviously pooched but I've got about 3 or 4 XJ's worth of parts and lift stuff at home so I figured it wasn't a big deal. Otherwise looked to be in very good condition. Didn't know about the 0331 head issue *facepalm*.
So yea, head is cracked. On the way home after buying it, got a CEL for low oil pressure. Wasn't making any obvious noise so pulled the pan (gasket needed to be replaced anyway) to check out the oil pump and pickup. Pickup was pretty clogged so cleaned it up. Pump looked okay. Tossed it all back together and OP still drops once warm. Did all the obvious checks, OP may very well just be the sensor but today I noticed the head crack and don't feel like ****ing with this thing anymore.
So that said, I'm sure I can get a pre-00 motor in there just fine, but the easiest way of course would be to just swap the ECU as well and call it a complete 98 motor/harness/ecu swap. Unfortunately, the 00 is an auto and I don't have an ECU for an auto. Looking for suggestions on donors.
I've got a 98 long block left over from my 5.3 swap. It had a few quirks, but always got me where I was going. I'd decided years ago that I'd put the v8 swap off until the 4.0L died, but it of course never did. As I kept building though, the 4.0L was feeling weaker and weaker and I thought it was close enough to dying to justify the swap. Then once I was finished the swap, I finally weighed my rig and it was 5000lbs . So it's entirely possible the old 4.0L was tip top, I was just too fat.
That said, the 98 did have a mysterious loss of coolant (I think) but it always starts instantly, pulls hard, and never let me down. I'm sorta torn about using it.
At any rate, 4.0L long blocks are a dime a dozen. I may just rebuild the 98 I already have, or I may even consider rebuilding the 00 and throwing a TUPY head on it. It's really mostly about downtime as the girl's been getting progressively more pissy about not having a vehicle. I've told her to drive her Jeep into the ground for now and I'll start putting together a swap package.
Option 1.
So, 98 block, head, accessories, and exhaust manifold with the 00 intake and ECU, I've heard should work. Caveats being that I either need to find a way to mount the coilpacks or find room for 3x2 coils somewhere. What gremlins am I going to run into?
Option 2.
Find a 2003+ 4.0L from a wrangler or a slightly later WJ and ... just drop it right in? I've never really worked on Jeeps later than 98 so I'm at a bit of a loss here. I know the wrangler got the TUPY head in 2003 but the grand perhaps later. What all would be involved in this swap? Just grab the long block and drop it all in?
Option 3.
Rebuild the 00 block, drop on a TUPY head, profit???
I've never done a complete rebuild. I'm sure it's not beyond my ability or inclination (I'd actually like to do a rebuild) but machine shop time here is nucking futz. Seriously. For what I've been quoted to pressure test a head, I could just go buy another used longblock. Assuming the 00 block needs work, I'm guessing i'd probably have to turn the crank, new cam, rod/cam bearings, lifters... anything else? Cylinder work required?
Option 4.
???? Any other idea's?
I'm almost seriously considering just tossing in another 5.3 for her. Cost me about $3500 to do mine and only took 3 weeks from the time I started gathering parts. I'm hoping to put less than another grand into the girls XJ as it's just a boring commuter, but I'm almost more comfortable with the 5.3 swap now than I am mixing and matching 4.0L parts .
Option 1.
Option 2.
Option 3.
Option 4.
