argalaviz
NAXJA Member #1248
- Centralia, WA
The drivers side window has been acting slow as of late and today finally stopped moving. The bummer is that it is stuck down and it's winter...
I have voltage to the motor when pushing the switch but the motor will not turn. I checked for any wierdness with the wiring and found a broken wire under the floor mat area of the drivers side which I fixed and now my power door locks work, which is nice.
So If the wiring looks good and the other window switches work on the control panel work is it possible that the motor is shot? I did search the forum and thats what lead me to pull up the carpets to check there.
