TerraWombat
- Eastern Shore MD
The truck starts and runs very poorly, kind of like how an engine runs when its way out of time. It’ll attempt to keep running, but will eventually stall out. Giving it gas causes it to hesitate for a moment before the RPMS increase, at which point it’ll frequently have a misfire. Sometimes the truck will start up and run like it’s supposed to, but only for a few brief moments, before it goes back into what I’ve described above. I’ve done a fair amount of troubleshooting on the truck, and have replaced a few items, such as the crank position sensor, spark plugs, spark plug wires, and the intake/exhaust gasket (which seemed to be leaking and sucking in outside air….I thought a new gasket would be the end-all cure, but it was not). I’ve tested other various sensors, such as the TPS, IAC, O2, MAP, and a few others. All of them appear to be in good working order. I also had all of the injectors cleaned and flow tested by a professional, but that did not cure the symptoms. I also rerouted a bunch of the vacuum lines and made sure there are no leaks.
I’ve got a few other ideas as to why it is running so poorly. I was thinking that maybe the coil has a poor ground and is producing a weak spark or maybe the distributor was removed and wasn’t positioned correctly upon reinstallation. It just seems weird to me that the truck will sometimes run decent, but most of the time runs like a POS. I welcome any other hints, tips, or suggestions that you may all have. I understand that my description may be a little vague, so if you have any further questions, I’ll be happy to answer them to be the best of my ability.
Thanks everyone for reading!
