- New Jersey
I think I'm finally set in what I'm going to get to redo the rear on my '96. To start, cause its badly needed, is the RE hack and tap SYE and an RE CV drive shaft. After everthing I've read about both items, they appear to be very good quality and the price is right. At first I'm going to run this with my D35, but will be replacing the 35 with an 8.8.
I've read that the pinion length of the 35 and 8.8 are very close, is this true?
Will I be able to buy the shaft now and have it be the right lenght for both axles?
Would changing the pinion flange on the 8.8 out for a yoke be a negative in any way?
Is identifing an 8.8 that has hot rolled electric welded axletubes as easy as looking for the seam? I've seen tube that has been made from rolling and welding sheet metal and there is a visible seam, do I understand that this the same process used on some 8.8 tubes?
Thanks guys.
--Matt
Thanks guys.
--Matt
