Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Ford super duty axles in a Xj
I like this topic and have been on a half search for a set. Ive made a few phone calls I've begged bartered but have yet to come up with a pair.
Right now there's a set for 1000 but I'm flat broke. So for these axles to go in my xj the housing will be stripped of all its brackets. Coil mounts sway bars everything. Itl probably get a truss before brackets go back on. On this one coil mounts and everything will start from scratch. Im not happy that I stripped my dana 30 but left factory coil mounts. Depending on axle link mount width i may need to cut my frame side link brackets and turn them so heims aren't ridding at misalignment. No i don't think ill run link mounts outside the frame. Wider link mounts on the axle will make alittle more triangulation helping the track bare locate the axle side to side. Rear is easy. And I may incorporate 1-2" of lift into spring pads cut from 1/4" plate. Its not time for me to link the rear yet. For wheels and tires ive already decided on h1 bead locks to keep stance as narrow as possible i may also looking into narrowing both axles if i feel its to wide. I'd like to anchor some axles to have for a winter project come into spring with a different little critter ready to hit the dirt. |
#2
Re: Ford super duty axles in a Xj
Not Superduty, but I narrowed my kingpin 60 by 4” off the long side only to control the width and bring the pinion 2” closer to center. WMS width then came to about 65”.
Hindsight, I would have considered narrowing it to match a “stock” D60 inner, Ford or Chevy or whatever, so I could order a chromoly shaft out of a catalog instead of full custom.
Spotters lead the way! My green junk. or #StellaFTH4 1989 XJ Wagoneer. Basically stock. G & G Offroad and Auto Repair can make you think you can run the Box! |
#3
I'm a 'Do-it-Twice' kinda guy. 1999 XJ Sport 4.0L Black |
#4
I check. I usually always check Elko, my cousins are there and can grab stuff when deals come up you can't pass up.
Sent from my SM-G960U using Tapatalk |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Ford Super Duty Dana 60 axles | choogala | Winterfest 2017 Swap Meet | 1 | February 21st, 2017 08:09 |
Ford Super Duty axles yes or no | BAC478 | Modified Tech Discussion | 13 | March 28th, 2011 14:16 |
Ford Super Duty & 65 Mustang | Prepmech | MWC For Sale/Wanted Forum | 4 | October 9th, 2008 15:02 |
Ford Super Duty Coils | RenegadeStang | SEC For Sale / Wanted Forum | 0 | December 12th, 2007 20:10 |
Ford Super Duty springs | Prepmech | MWC For Sale/Wanted Forum | 3 | October 15th, 2007 15:30 |
