Old November 19th, 2020, 06:05
TEX-J99 TEX-J99 is offline
Adjustable Lower Control Arms
Hello, I am new to this forum and have a question about adjustable control arms.
I originally installed my LCAs with the jam nut on the frame side. However, I recently took my '99 XJ into a reputable local off road shop and they said I had them backwards and the jam nut side should be low at the axle. He said I'd only notice a difference when off road possibly and not on pavement. Something about the mounting brackets and the different style ends of the LCAs.
Most that I have seen seems to have the jam nut on the high side, although I have seen it both ways.
What do you know about this?
The photo is of a mechanic on YT installing them on the axle side, but I have seen other mechanics reversing them.
Sent from my SM-G950U1 using Tapatalk
Old November 19th, 2020, 06:23
I think I may have just answered my own question (emphasizing the word, "think").
It seems as though when the suspension is articulating, you'd want the more flexible joint to be on the axle side, where as the less flexible bushing joint would be up at the frame where not as much flex is happening.
Sounds logical enough, right?
Old November 19th, 2020, 06:33
RCP Phx RCP Phx is offline
Re: Adjustable Lower Control Arms
If the arms are straight it really doesn't matter, if the arms have any shape then that's built in for bracket clearance and generally the shorter end goes to the axle. Joint types (poly/rubber/flex-joint) do not make any difference.
Old November 19th, 2020, 07:34
Evan03 Evan03 is offline
Im running poly on the axle side because feel it doesn't flex theres. Heims on frame side because these joints need to follow the axle side.
Old November 19th, 2020, 07:37
Upper is heims both ends. Mostly so I can adjust castor by turning bar. Don't have to take anything apart.
Old November 19th, 2020, 07:53
That's very questionable!
Old November 19th, 2020, 08:28
Anak's Avatar
Anak Anak is offline
Stranger
My bet is that you were dealing with someone who simply wanted everything assembled so it was more convenient for him to work on it. Putting the jam nuts up higher meant he had less clearance up there.
Old November 19th, 2020, 09:12
I actually had already installed it with the heim joints on the upside. So he commented that they were reversed when I had it in there for something else.
Old November 19th, 2020, 10:20
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
Which shop? Baertrax?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
WTB adjustable lower control arms akelts Arizona For Sale/Wanted 2 September 29th, 2010 15:04
WTB: Lower adjustable control arms. bosco01xj SEC For Sale / Wanted Forum 5 February 25th, 2010 11:27
Adjustable Lower Control Arms! Jimbo_1321 Wanted: Private Party Only 1 October 20th, 2006 08:18
Non-adjustable/adjustable lower control arms Stick Wanted: Private Party Only 5 March 21st, 2004 17:23
Adjustable Lower Control Arms reson46 Modified Tech Discussion 3 December 1st, 2003 16:13
