Old July 31st, 2020, 19:50
2DOORDAN 2DOORDAN is offline
what tire size to run on stock axles
hi to all the members new on here I've gotten great information and had helped out greatly now the question o have is im adding a few things and here is my rig and suspension I'd like to add for light to moderate wheelin
94 2 door xj 4.0
5 speed
adding a R.E 3.5 lift
looking for a suggestion on tire size
heard I'd lose some power and torque at 33s
any good 32 inch tire by brand that is recommended
thank you to all in advance
Old July 31st, 2020, 19:59
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: what tire size to run on stock axles
31's is probably as large as you want to go on stock gears. At 3.5" of lift, they fit right and look good. 32's or 33's will very likely rub and require trimming of sheetmetal and/or plastic bits.
Mud Terrain tires are loud on pavement and are crappy snow tires. All-Terrain tires will handle anything off-road except knee deep mud, and will last reasonably long with pavement driving.
People are dumbfounded when I tell them I know how to change the spark plugs on a car.
Old August 1st, 2020, 11:41
Agreen Agreen is offline
I suggest 31" Firestone Destination XT. They're better than AT tires and nowhere near as loud as MTs. They just hit the market last year around July I think, so naturally I've had them for about a year. For a 3.5" lift they're an absolutely perfect fit.
What's the gear ratio?
Old August 1st, 2020, 12:29
lawsoncl lawsoncl is offline
I'd guess 3.07, based on 4.0 and manual. Going to 31s will drop your rpm about 10%.
Old August 1st, 2020, 15:52
Holy sheet 3.07!? Most junkyards have a plethora of XJs with 3.73 ratios.
Old August 1st, 2020, 17:06
Yeah, my MJ started on stock 215s, manual, and 3.07. It got 21-22 mpg on mostly highway. You had to downshift to 4th on steeper hills. I've since lifted about 5.5", 32s, and 4.11 axles from a 4-cyl and get 16-17 mpg.
I believe the 3.73 was only on the 4.0 auto with a tow package, and the real old 2.8 v6 Cherokees, which is where I recall grabbing my speedo gear. There are plenty of direct swap 4.11 axles out of 4-cylinders in the junkyard. Even more 3.55 out of the 4.0 autos.
Old August 1st, 2020, 19:47
Weird. Mine was a base model 2wd automatic and it didn't have a tow package. The ratio was 3.73 (C8.25) and the donor for the 4wd swap was nearly identical in every way except it was 4wd, no tow package and 3.73 gears.
Old August 1st, 2020, 20:05
I'm going by my recollection and https://en.wikipedia.org/wiki/Jeep_C...le_gear_ratios
Old August 2nd, 2020, 05:44
RCP Phx RCP Phx is offline
Originally Posted by lawsoncl View Post
That list is probably for US domestic sales, quite a few of the fleet vehicles they bought here in AZ had 3.73's. That list doesn't even list the front Dana 44 that was used in the Mexico/S. America model XJ's.
Old August 3rd, 2020, 15:24
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
I'd suggest no larger than 31/32. Also, consider finding a set of axles from a 4.0/auto XJ, which would be 3.55s , would keep you near stock gearing with larger tires.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old August 4th, 2020, 04:32
75SV1 75SV1 is offline
http://www.grimmjeeper.com/gears.html
I'd get some 3.55 axles. Then should be good for 31's to 33's. 3.73 are a bit scarce for XJs. I have a set on one I am building. I nabbed the front from a ZJ. The rear is a Ford 8.8. I'll be on 30.5" tires. You want 1800-2000 RPM at 65 mph. Since OR, so Mountains, I'd gear up a bit. Might loose a bit of MPG.
Edit: mines an auto.
Old August 5th, 2020, 19:36
ChuckQue ChuckQue is offline
I put on Falken’s Wildpeak AT3W’s in 265/70/R17’s, with a RE 3.5” lift (3/4” front spacer as well), Dana 30, 8.25 rear. Love them! Great for highway driving, very quiet, looking forward to trying them on A trail. Reviews were great, and Walmart had them for a really good price delivered.
I do need to trim and bump stop though.
Old August 6th, 2020, 01:59
denverd1 denverd1 is offline
Most 285s will run about 32. Someone said mountains so 31 would be best
biggest allowable tire size with stock axles? danja2 Modified Tech Discussion 45 October 31st, 2011 21:32
Anyone with a stock size tire? bmyohn MWC For Sale/Wanted Forum 5 September 16th, 2010 19:43
4.56 gears at stock height stock tire size Muad'Dib Modified Tech Discussion 25 March 27th, 2008 16:40
Stock tire size k_kuch OEM Tech Discussion 11 July 4th, 2007 11:00
Got new axles, what tire size/ gears? ZachMan Modified Tech Discussion 12 March 8th, 2004 20:41
