Thetastycat
- TN
Hey all - trying to remove the tranny/TC crossmember. 3 bolts came out fine, one turns with difficulty and makes a metallic squeal. Searching seems to indicate the weld on the nut, buried inside the frame, broke loose. The bolt is still intact and is single-handedly holding up the crossmember; what's the best way for me to get it out?? I could grind the head off or sawzall it but then I'm stuck with a bolt shaft to figure out how to get off before I guess I retap bigger to give the crossmember 4 strong bolts...what do you all think is the best way to get it off??
Thanks a lot!!
Thanks a lot!!
