Old July 31st, 2020, 05:21
Unclewolverine Unclewolverine is offline
Mopar tps
We have had flash flooding here lately and I think I've fried yet another cheap Chinese tps. I went to look for a mopar tps and I can't find one! All I see are for 97+, nothing for my 95. One site said they were discontinued. Anybody see them anywhere?
Old July 31st, 2020, 07:53
RCP Phx RCP Phx is offline
Re: Mopar tps
Your asking for a lot, I can barely find Mopar parts for my 2k these days! It might be possible but you'll need to know all the part numbers that will interchange and then do some serious searching.
Old July 31st, 2020, 09:51
Re: Mopar tps
All I know is every time someone mentions a sensor problem everyone says you have to get the mopar sensor, well apparently they don't exist any more!
Does the newer sensor read the same? I could splice on the newer pigtail easy enough.
Also, where can you get an analog multi meter anymore? I would like to properly test the tps readout but you can't do that very well with a digital one, and i checked lowes, autozone, and harbor crap; no one even knew where I could get a new analog mm.
Old July 31st, 2020, 10:18
8Mud's Avatar
8Mud 8Mud is offline
Re: Mopar tps
https://www.rockauto.com/en/parts/mo...r+(tps),51 36
68405575AA or 4761871AB
I've had pretty good luck with Standard parts concidering you can buy two for the price of one MOPAR
IMO and expereince none of them are waterproof or even mildly water resistant.
Disclaimer double check my numbers and application years etc.
Old July 31st, 2020, 12:00
Ralph77 Ralph77 is offline
Re: Mopar tps
Thinking the part number is 56026921.
https://www.moparpartsgiant.com/part...tra2=&filter=()
https://www.amazon.com/Mopar-5602692.../dp/B006EFUDV6
Old July 31st, 2020, 12:04
Re: Mopar tps
Originally Posted by Ralph77 View Post
Thanks but those are cps, I'm working on my tps. I'm thinking I'll just warranty it back out and coat it in silicone this time!
Old July 31st, 2020, 12:14
Re: Mopar tps
My bad I need to be wearing my reading glasses more often.
Old July 31st, 2020, 13:09
75SV1 75SV1 is offline
Re: Mopar tps
Also try Ebay with the MOPAR PN. The 68405575AA had some selection.
Old July 31st, 2020, 14:12
Saudade's Avatar
Saudade Saudade is offline
Re: Mopar tps
My parts guide say there are 2.
Part number 56026921
Part number 56027865 - XJ with sales code XCY. I think these are for later production '96 XJ
Having said that I been using NTK or Standard Products in my Renix lately. The CPS I've been running for about 10 years came from Autozone.
Edit: opps I got confused too. The part numbers I post earlier are for the cps not tps. I have a cheap tps on mine. When I wash off the engine, I disconnect the iac and tps harnesses and cover them with a ziplock bag to keep water out. Then a blast with my air hose to blow off excess water before I uncover and reconnect.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 206K
Old July 31st, 2020, 18:14
Re: Mopar tps
Changed it out again. Like last time all the issues cleared up. It is a standard brand sensor, made in Mexico. I didnt remember what brand oriellys had given me. This time i smeared some right stuff on the mating surface and the seam all along the back. If it can seal my oil pan and valve cover, surly it can keep some moisture out of a sensor. It will be a severe pain if I ever have to pull it again though!
Mopar 360 In XJ 1985xjlaredo Modified Tech Discussion 44 September 15th, 2019 12:05
CPS Mopar? WTF! pezman65 OEM Tech Discussion 19 September 15th, 2018 08:11
Mopar 240/240 140657 Jeep Street and Performance 2 June 25th, 2010 14:07
Mopar 360 and AX-15? swbooking Modified Tech Discussion 15 June 16th, 2008 10:46
THANK YOU MOPAR!! jeepman121 OEM Tech Discussion 7 February 26th, 2008 12:13
