Old July 19th, 2020, 08:40
2DOORDAN 2DOORDAN is offline
NEW 94 2DOOR HAVING FUEL ISSUES
how is everyone glad to be on here just bought an forest service jeep 2 door 4.0 5 speed with 131k on it has some minor issues that i would like to address and get running correctly before any type of mod is done to my vehicle all advice and expertise welcomed...
Old July 19th, 2020, 08:55
RCP Phx RCP Phx is offline
Re: NEW 94 2DOOR HAVING FUEL ISSUES
What problems are you having???
Old July 19th, 2020, 09:08
fixed the tps it was on backwards that was the first issue ran fine still does no check engine light but yesterday it had a hard time starting I turned the key on and off a couple of times thinking maybe I could hear the fuel pump priming after a couple time it started..
appreciate the help
Old July 19th, 2020, 09:25
Agreen Agreen is offline
When it doesn't start, you need to find out if it's spark or fuel. Start with spark. Get a cheap spark tester and put it inline with a spark plugs and wire. If you don't have spark, we can help you chase that. If you do have spark and it still isn't starting, check fuel pressure. If you have both spark and fuel pressure, it could be an issue with the ECU not letting the injectors fire. There are many things it can be, but you will have to gather the requested info when it doesn't start.
Old July 19th, 2020, 09:27
10-4
Old July 27th, 2020, 20:47
I've replaced the fuel filter so far and it sounds a little better pressure is good on the rail ..
looking also into changing the header and exshaust all the way back any suggestions appreciated
Old July 29th, 2020, 04:59
75SV1 75SV1 is offline
What spark plugs are you running? Did you look at the cap and rotor? Coil?
As for header, I am running a Doug Thorley. Some like the Banks. I just received the 'cat back' system from Iron Rock. Also, the ignition module up by the key, might be an issue. Also, replacing the injectors might help it run better. The Ford 4-holes are a good inexpensive solution.
Old July 29th, 2020, 08:51
was looking on iron rock what cat and muffler the o2 sensor plug is not on the cat on my stock exhaust wouldn't mind the magnaflow just want to know which one along with the muffler
thanks
the cap rotor and plugs were replaced brand new by previous owner less than 2k ago but I'll check all out
Old July 29th, 2020, 08:59
mongolchuck mongolchuck is offline
How was your fuel filter? If it has ever been run without a filter or with a very plugged filter it doesn't take much to plug the injectors. Obviously first check your spark and air but plugged injectors are not uncommon.
Old July 29th, 2020, 09:13
thanks mongolchuck when I can I'll be sure to check the injectors changed the filter and it runs better and starts up i will be looking into purchasing the 4 hole
any suggestions on type or part number
thanks brutha
Old July 29th, 2020, 09:37
The best set I found before my stroker was 0 280 156 007.
Old July 29th, 2020, 11:31
Did you check the battery voltage? Battery cables? Voltage to the PDC (Power Distribution Center)?
Old August 6th, 2020, 18:08
battery was good cables plugs all good
grounds good 👍
fuel pump is good
Having some fuel issues.... johnnybyron OEM Tech Discussion 6 November 6th, 2018 17:10
YJ fuel pump used in cell fuel delivery issues barillms Modified Tech Discussion 4 June 15th, 2013 18:19
Fuel Issues? ezmoney333 OEM Tech Discussion 9 November 21st, 2012 14:13
Having issues getting fuel..... 00DCJeep Modified Tech Discussion 10 June 17th, 2010 04:55
Please Help, Fuel Issues juicexj24 OEM Tech Discussion 2 October 2nd, 2005 20:00
