Old July 29th, 2020, 20:07
Jeepmedic46's Avatar
Jeepmedic46 Jeepmedic46 is offline
Oil pressure issue
When I start my 2000 XJ the oil pressure gauge reads 60 at idle then under load goes up to 80. Going to try a new pressure sending unit to see if that solves the problem. I donít have a gauge to see if the gauge is correct. The Jeep has the proper amount of oil in it. Is it ok to drive it. Iím going to need to drive it to pick up the new part. Does anyone know what size socket I need?
Old July 30th, 2020, 13:55
old_man's Avatar
old_man old_man is offline
Re: Oil pressure issue
Short answer is that it should be fine. Upon first start up, the pressure will be higher until it warms up.
Have you recently changed the oil/filter?
You don't say what brand and viscosity oil you are running.
Worst case I might change the oil filter, especially if you are running FRAM.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old August 8th, 2020, 17:18
2X_01_Jeeps 2X_01_Jeeps is offline
Of the 3 Cherokees I've owned (1984, 2001, 2001) 2 of them have had oil pressure senders fail such that they read way too high. They would read idle pressure normal but revving the engine when hot would indicate 80 psi which is virtually impossible.
If your oil viscosity is correct this is your likely problem.
Oil pressure issue dirtyjerseyjeep OEM Tech Discussion 9 January 6th, 2013 12:13
oil pressure issue acmetrapper62 OEM Tech Discussion 18 June 6th, 2011 21:32
Pressure Issue? 89heepxj OEM Tech Discussion 2 June 10th, 2009 11:09
Oil Pressure Issue? axshon OEM Tech Discussion 9 May 26th, 2008 10:01
Oil Pressure Issue nhrocker OEM Tech Discussion 6 September 17th, 2006 11:31
