- In the islands
I am the process of replacing the timing set on my XJ. I bought a set from Rock Auto. The crankshaft gear is tighter tan the one I removed. It may fit if I tap it on. For the camshaft, it is different. At a glance, it seem to be good. however, the face of the gear/sprocket is different. The face were the bolt and washer fits have a ridge unlike the original which is smooth. In other words, the washer would not cover the same area the original covered because of the machined ridge. Is there a different washer that fit there?
Te part number is S808 and is made by melling.
