1dayiwill
- Perdido Key Fl
I have read a tremendous amount on pretty much everything xj since I got my 1996 2wd 4.0 a week ago. I plan on making it 4wd eventually but im not really worried about it now since Im DD this for a while. The only offroading I do is a trail area that opens up to some sand and a small amount of ditches that get muddy so nothing serious, just a little of everything. I also plan on going 31 a/t whenever a deal pops up on ebay or craigslist for a set with decent tread remaining and price of course.
So Im looking to lift between 2-6 inches, I know big gap but Ill do whatever funds allow. I want to homebrew pretty much all of it.
I read that v8 grand cherokee coils will give about 1in of lift. So that means that aftermarket grand cherokee coils will fit the xj, correct? Or are there certain years only?
I also read that yj rear lines are often used for their extra length but will aftermarket tj lines fit the xj? I ask because I found a deal for some longer SS tj lines.
Next area of uncertainty- bumpstops. When, how, and why do I alter or add more? I mean, what size lift do you begin to give attention to them and what do you do to them and why do this.
Now for shocks- I guess Ill do the BPE when I remove my swaybar since its free but I still havent really figured out the advantage of doing this other that using an F150 shock or something? Any suggestions on what low buck shock to get from whatever vehicle for whatever amount of lift?
And last for the moment- when and what do I start dropping steering wise? When do adj trac bars and ca's and pitman arms and all become needed and what is each need for. Ive read generalitys on the web but havent found much specifically aimed at the xj.
And along with the last subject, being that Im on a full time students budget, is there anything I can use off of, for instance grand cherokees instead of buying new adj or drop components. I think I read the grand cherokee pitman arm will work for some amount of drop but i dont really recall.
Any help or additional input not along the lines addressed above is much appreciated.
Thanks, Ian
Thanks, Ian
