tsill
- Cincinnati
I was installing a new pan gasket and rms and lightly put a very tiny scratch in the lower main cap where the rms seal sits. I also barely and I mean barely nicked the rms seal where it sits in the lower main cap. I now have a constant stream of oil coming out of the back when running. I put rtv on the main cap on both sides extending at a 45 degree angle just like the manual shows. I also put rtv on four corners of oil pan gasket where it meets the block as described. I'm thinking either the scratch/nick is the issue but am leaning toward not having rtv somewhere I should. The manual says to put rtv on the back of the cap where it meets the block? All the way around the on the back face? It may also be the oil pan gasket fell in on the back side when moving it around. I tied fishing line in some holes to keep it straight but it was tight getting it back in and it moved. Any thoughts. I dont have time to redo this and will probably take it somewhere to get fixed.
