Suspension wobbles
kearnsy
australia
:I have a 96 xj running
-3.5 inch lift rear
-2.6(average of two sides) inch lift front consisting of 40mm spring 20mm spacer(left side 3.3 inch Right side 2.6 inch)bit of sag
- tryes 30.9.5 bfg ats
-transmision spacers
-gen 2 rubicon sway bar disconects /ajustable swaybar
I have replaced all the controll arm bushes, ball joints in good condition
have just had the caster adjusted (+4 33'degree)still have suspenion shake when i hit a series of bumps small even
and now have a drive line vibration( front) when all wheel drive engaged 40kms and up
Any ideas? please. getting to my witts end spent ages trying to get it right
thinking of ripping lift out going back to a 40mm lift love extra height though:wierd:
1. Welcome to NAXJA
2. There's a search button that helps with common problems like these...There are TONS of DW threads.
3. +4 caster is too much. also, check TRE's and trac bar. Take it to the alignment shop if you havent done so after you installed the lift. Good luck!
