Old March 28th, 2017, 18:43
Jeep Driver Jeep Driver is offline
Re: Feeling weak (rebuilt 4.0, 4.56, AW4, 31s...), Why?
Originally Posted by cherokeefan_1 View Post
I agree with johnx 100%. That's why you should always degree a cam when installing it. Just because it's new or a regrind does not mean it was done correctly or that the timing set was made correctly. If you've built numerous engines this becomes very apparent as each cam can show slightly different timing, even among the same grinds.
Which adjustable timing set do you have? because I have yet to see one.
When was the last time you dialed in your cam? How often do you dial it in?
I'm +4 at the crank, Mopar Performance (Cloyes) double roller. Most guys bitch and complain about $60 for a stock set...........
You?
Old March 28th, 2017, 20:40
cherokeefan_1 cherokeefan_1 is offline
I've only built high performance SBC,BBC, and drag race 440's so all had adjustable sets put in them and all get checked and adjusted. Bushings can be used or you can buy adjustable gear sets. When I build stuff I don't go cheap as that's what you get when you do, cheap. Not all cams work well advanced/retarded some work best straight up. Some need to be adjusted a bit to get them to the correct specs.
Old March 28th, 2017, 20:42
You can even get offset crank keyways but I don't trust them.
Old March 28th, 2017, 21:26
clydefrog's Avatar
clydefrog clydefrog is offline
Originally Posted by notamos View Post
Thoughts?
Honestly. Time for an LS swap.
Sorry, I am no help, seriously though. Slow XJ got you down...LS swap!
Old March 29th, 2017, 06:39
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
I am constantly amazed by how much of an idiot jeep driver is.
And yes I'd be looking for a compression test as well, followed by fuel pressure test under load.
I've retimed the cam on 4643 several times now and it makes a *drastic* performance difference, but its not less or more power, just moves the curve up and down the tach. I doubt the issue would be there. With the distributor off a tooth it is a clear problem, as it either won't want to idle or won't want to rev up.
Did you re-use your fuel injectors or replace them? I don't remember reading that.
Old March 29th, 2017, 06:57
Green XJ Jeep Green XJ Jeep is online now
NAXJA Member 4950
With the cam, timing set and lifters that the op used I seriously doubt that its the issue if it was installed straight up and properly broken in.
Old March 29th, 2017, 07:43
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is offline
NAXJA Forum Addict
I've retimed the cam on 4643 several times now and it makes a *drastic* performance difference, but it not less or more, just moves the curve up and down the tach. I doubt the issue would be there. With the distributor off a tooth it is a clear problem, as it either won't want to idle or won't want to rev up.
I'm more amazed by the arrogance than the stupidity to be honest.
John V.
Director at Large
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old March 29th, 2017, 10:12
Show me an adjustable timing set for the 4.0
Post it.
Old March 29th, 2017, 10:18
cal's Avatar
cal cal is offline
https://www.amazon.com/JP-Performanc.../dp/B00TO63LE8
That's the one I currently run. -8 to +8 in 2* increments.
https://www.amazon.com/Cloyes-9-3127.../dp/B000NGN6NE
Cloyes -4 and +4. I've run this one in the past.
Here's the post where I changed from one to the other.
http://www.naxja.org/forum/showpost....postcount=1766
I know for a fact there are others out there, but these are the two that I have run in the last year alone.
Old March 29th, 2017, 10:35
cal's Avatar
cal cal is offline
I'm not sure how you can claim it doesn't exist, and talk about using one, in the same post.
Your claim to idiocracy is more general though.
Old March 29th, 2017, 10:38
That's not exactly dialing it in.
Old March 29th, 2017, 10:39
You don't know how to read do you read my post where I say that I am + 4
Old March 29th, 2017, 10:40
cal's Avatar
cal cal is offline
You're the only person here who's ever used the phrase "dialing it in".
We're talking about a glorified tractor motor that appears to not have a timing problem, so if you would kindly, quit yammering on and let us get back to the OP's problem.
Old March 29th, 2017, 10:42
I'm the one that said he had a tuning problem I'm also the one who said he does not have a timing problem
I believe it is you who has the issue
Old March 29th, 2017, 11:02
Hypoid's Avatar
Hypoid Hypoid is offline
For diag "tools", I have a timing light and Torque on my phone. Any basic tests you could recommend?
I am not familiar with that app. Can you cruise around and see if the ECU is in open, or closed loop?
So far, Trippled has given the easiest, and cheapest advise. If you find something, you find something. If you don't find anything, you can push controls to the back burner while looking at the mechanical aspects.
Something like this could make for a good Chapter Tech Day, if we can talk old_man into it.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
I have a Bad feeling about this... jesterbomb OEM Tech Discussion 10 August 2nd, 2007 16:21
What is about the average price to have a 4.0 rebuilt and a AW4 rebuilt? newjeepowner OEM Tech Discussion 7 June 27th, 2006 19:31
just getting a feeling.... outlander For Sale: Private Party Only. XJ ITEMS ONLY 5 February 27th, 2005 10:57
feeling a bit sorry for myself Beej Non-Tech / Off Topic 7 December 18th, 2004 14:25
