Old December 14th, 2016, 17:31
LKN_xj LKN_xj is offline
1991 XJ Limited - Project "It's About Time"
Originally Posted by 90xj06 View Post
what head casting is it? im not 100% sure but the 7120 and the 0630 have the same port setup. but the 0630 does not have the threads for the temperature sensor for the dash. you can drill and tap or make something creative.
I am not sure what you mean here. I also don't know what head I have.
Old December 14th, 2016, 18:09
Originally Posted by LKN_xj View Post
I got everything buttoned back up to test for fuel leaks. I'm not leaking at the injectors, but I am leaking a few drops from leach fuel line connector going into the fuel rail.
What is the likely cause of this?
A little research helps I guess - it appears I need new o-rings and you can individually buy them at NAPA.
Old December 15th, 2016, 05:48
90xj06's Avatar
90xj06 90xj06 is offline
Re: 1991 XJ Limited - Project "It's About Time"
sorry about that posted that in the wrong tread.
Old December 16th, 2016, 06:31
She lives! Got her started up last night. Shot straight to 2k RPMs and held there. I searched for a vacuum leak for a few minutes until I realized my throttle cable clip on top of the valve cover wasn't in the bracket all the way. Problem solved.
I will definitely have to get used to the added harshness of the motor mounts. Definitely not OEM but it feels more "connected" when driving for sure. Just a bit of vibration at idle.
So far, not a drop of PS fluid or antifreeze in the driveway
Old December 16th, 2016, 13:59
Dang it!! Spoke too soon. This is power steering fluid.
Can't figure out where it is coming from. The return hose is wet but it's not dripping from there. It's coming from the same spot it was before I replaced it. Dropping down from right above where the lower radiator hose clamps to the water pump.
Old April 5th, 2017, 06:48
Lots of updates since the last post. Nothing too crazy, just some needed updates.
Lost the tire carrier, changed the door trim to something more robust, added a stubby front bumper and some EBay lights.
Replaced the rear main, cleaned up 350k worth of grime and oil, replaced the oil pan gasket with a fel-pro. Also going to swap in my lower mileage D30 while I'm at it.
Old May 1st, 2017, 06:04
More updates, went with the B.Lees 3-link, swapped in my lower mileage Dana 30, and threw 1 more inch under the front. Oh, and 'Merica stickers!
Old May 1st, 2017, 20:06
Gotta get longer brake lines to flex it out, but here's a glamour shot.
Old May 2nd, 2017, 09:24
Kittrell's Avatar
Kittrell Kittrell is offline
Looks great, what are the wheels specs?
Old May 2nd, 2017, 09:30
Thanks - I picked the wheels and tires up second hand, but they're ion alloy 15x8 and I believe 3.5" back spacing. They're like these:
https://www.quadratec.com/products/9...6KswodVmYI 6A
Old May 2nd, 2017, 09:57
Kittrell's Avatar
Perfect thanks, I have the iON 171's waiting to go on. So that's exactly the backspace I will be seeing. iON marks them as 3.44 BS, not sure why QT rounds up.
"Part Time" Dash light.... I need mine to say "Party Time" mako my day OEM Tech Discussion 23 March 2nd, 2013 06:36
Gear oil for "Limited Slip" Do I still add "additive"? my2monkeys OEM Tech Discussion 1 February 5th, 2012 08:43
1991 Jeep Cherokee Limited 4.5" IL Fast95Neon MWC For Sale/Wanted Forum 4 October 19th, 2008 19:45
3" lift and limited time Poppinblock Modified Tech Discussion 2 April 17th, 2006 23:16
