Blaine B.
- Northwest Indiana
Hey, just wondering if some of you can give me ideas as to how long the rear driveshaft is that you are using with a lift between 7 and 8"? With a Chrysler 8.25 rear axle.
I've got an Advance Adapters SYE waiting patiently for me to install it along with a Tom Wood's driveshaft. Before I install the driveshaft I want to be sure it will be long enough for 7 to 8 inches of lift.
I believe the box that the driveshaft came in said it was a 32" shaft, although I believe it is a bit longer when fully extended. It looks to be shorter than the origional shaft though, and the origional setup has a long cone attached to the output housing on the transfer case.
I hope my new Tom Wood's shaft will not be too short.
Thanks in advance!
Thanks in advance!
