- Austin, Texas
I'm in desert west texas atm, and I have a problem where the Jeep cold starts and drives fine, but after 10-20 miles I'm getting a wheel RPM dependent squeal once per revolution as the car slows to 10ish MPH. This gets worse as the car heats up. There is also a noticeable braking effect with the noise, as if tapping the brake each time. I've taken it to a mechanic but they're saying nothing looks wrong with it. I'm changing the wheel bearings out just because I had the parts in my road bag, but need to figure this out as I have 700 miles left in the trip and don't want it failing outright or catching fire.
What should I be looking at? Drum brake adjusters? If so how (will be searching the forums concurrently).
1998 XJ AX-15
1998 XJ AX-15
