- Colorado
Ok, shackle box is fine. But I'm finding marks on frame, body each side. Longer or boomerang shackle the fix?
I think it was pointed out that the bolt is running the wrong way? Find where its rubbing and picture a linger shackle, does it still? Boomerangs are nice. Adjustability for where it mounts is nicer! Decide if you are going to use the parts you have would be my recommendation. If so, install it with bolt the right way and go from there. If not, a no lift SRB like sfr is the business for dialing in shackle angle... the HD shackles you had shared look fine to me
