Old May 3rd, 2021, 13:21
steventure steventure is offline
Vista pro heater core updates?
Is this still the best option, did it last? I think Iíve read every heater core related thread out there. Parts stores seem to be a crapshoot either way and the vista pro is certainly pricier. So is it worth it is what Iíd like to hear.
Old May 3rd, 2021, 13:49
maxbraketorque maxbraketorque is offline
Re: Vista pro heater core updates?
If you don't mind spending a bit more money, then consider this:
https://www.superiorcooling.co/48740...-wrangler.html
Old May 3rd, 2021, 17:44
I believe thatís the Vista Pro one, same part #
Old May 3rd, 2021, 18:11
RCP Phx RCP Phx is offline
But it's not a copper core, big difference!
Old May 3rd, 2021, 18:22
tech1001 tech1001 is offline
I've been looking at one of these heater cores , One is copper core and the other is a Aluminum but I think the cores are the same thickness so I think they should both put out good heat.
https://www.radiatorexpress.com/part...ee/base/40l-l6
Old May 3rd, 2021, 18:27
Yes they are both copper. It seems superior cooling just sells the vista pro model, same part #
Old May 3rd, 2021, 18:29
Interesting I hadnít come across those yet. Will have to give them a call tomorrow, thanks
Old May 3rd, 2021, 19:42
asymptonic asymptonic is offline
I'm curious why folks like copper core heater cores better than aluminum? Aluminum is more flexible, gives up heat more readily, etc. I would think the copper cores might be slightly more resistant to damage, but aluminum is better for transferring heat from liquid to air than copper. Copper is more conductive if you're talking direct contact conduction, but that's not what's happening in liquid to air. Same reason radiators are aluminum, you want to convert air heat to liquid heat in a radiator. The exact opposite but same principle in heater cores?
1998 4.0 I6, AX15, NP231
Old May 3rd, 2021, 20:27
Iím not opposed to aluminum. But Iíve read too many ďfailed after 2 monthsĒ reviews.
Old May 3rd, 2021, 20:47
Most of the aluminum cores are thinner almost haft the size of the copper cores so they can't put out a good amount of heat .
Old May 3rd, 2021, 20:51
399233 is the OEM part number. I just pulled my Superior Cooling Co heater core out of its box, and its in fact a TSM copper/brass heater core.
Where are you seeing a Vista Pro copper/brass for sale?
Old May 4th, 2021, 04:09
eBay/Amazon and they show the same part number. Thatís why I figured theyíre the same just reboxed
Old May 4th, 2021, 04:13
How is the quality? Do the solders look ok, did it come wrapped with foam, how does it fit?
Thanks, more than likely the one you linked is the one Iíll go with
Old May 4th, 2021, 05:53
I've got one of the Superior cores, the workman ship is great but no they don't come with any foam.
Old May 4th, 2021, 06:14
The main reason why people purchase the copper core is because it's such a PITA to do you will not want to do it again!
Heater Core/Heater valve tylergrant2011 Jeep Comanche MJ (1985 - 1992) 6 October 5th, 2015 17:41
Changing evaporator core - thinking of reusing heater core jeepingben OEM Tech Discussion 6 March 29th, 2013 16:28
Heater core HELP!!! Blue 97 XJ OEM Tech Discussion 14 November 21st, 2009 11:15
Heater Core? jdxj OEM Tech Discussion 3 July 12th, 2007 15:46
How to access heater core...question about core? nosajwp OEM Tech Discussion 1 November 11th, 2004 12:16
