96 jeep window issue
Glenbaumann
Wisconsin
I have a 96 jeep Cherokee classic. The driver window dont work. Hit the switch and hear the click of the solenoid kicking in bit the motor dont move the window up or down at all?? Any help with this would be very appreciated.
If your Drivers window does not work. verify continuity at the motor. or replace the motor.
not really anything more to tell...
Apply 12 volts directly to the window motor. Test wire continuity from switch to motor. Test wire plug for voltage. Consider that the drivers door switch is faulty.
