family XJ
- Jacksonville North Carolina
First is pertaining to my brothers 89 w/4.0 and 120k miles. It sat for over a year and now smokes really bad. My thought is that the valves are gummed up and not open/closing properly. Should we take off the valve cover and clean it with degreaser then change the fluid or add 1 qt of ATF then run it get it hot and change the oil. Suggestion for this one. He is killing people when he takes off at the stop lights.
Second. On the water pump can I just use RTV or do I really need a gasket. My water pump is squealing really bad and my wife is embarrassed. It works fine just makes a ton of noise. I want to change it and make it quite again.
Thanks for the help Doug
