gentry20
- dayton,oregon
i have a 88 xj with the 4.0 and i want to put larger fuel injectors. can find any larger ones. need to know what other vehical injectors work thank you
Why? Bigger injectors won't necessarily make it faster, fuel / air ratio is controlled by the computer and the engine can only flow so much air, besides it's a relatively low speed engine.i have a 88 xj with the 4.0 and i want to put larger fuel injectors.
Do these guys have the LT1 injectors on their site that have been recomended as an upgrade?Check out www.precisionautoinjectors.com. He offers great technical support as well as reasonably priced flow-matched injectors for our Jeeps. Fast shipping, too. Bought a set last week and installed them. Nice performance increase, smoother idle. I'll check mileage on the next tank of gas..........
Which ones are these?, part # ?i just bought Ford 710 injectors. It is to my understanding that i need a newer fuel rail and pressure regulator from a chrysler? is this right?
Well, if you have OBDII and/or the capabitily to cut back the fuel trim, then they would probably be okay. But definitely not for a renix, would run way too rich.I run LT-1 injectors from a '96 Caprice w/LT-1. They are 24-25lb at 49 psi. Mine is a stroker, so it can use the extra fuel.
I don't know if I agree about these being too rich for a stock motor. I would think that there is enough adjustability to "pull back" and not flood the motor.
