Old July 25th, 2014, 21:08
88_xj_ 88_xj_ is offline
Overheating issues!?
I have an 88 xj 4.0 it is having some over heating issues while driving around town if i keep the rpms under 3000 then the motor runs fine and the temperature is at normal temp. But anytime i rev it past 3000 like if i take off pretty hard the temp starts to rise pretty fast. Im wondering if anyone knows y this is happening
Old July 26th, 2014, 07:07
87manche's Avatar
87manche 87manche is offline
Re: Overheating issues!?
stock cooling system?
toss it in the trash, spend $300 and swap it to the open system with new hoses/pump/thermostat.
enjoy not messing with it for the next 5 years.
serious. If you've still got stock 27 year old parts in there it's just time to wholesale replace the system.
Old July 26th, 2014, 19:40
88trailcrawler's Avatar
88trailcrawler 88trailcrawler is offline
Closed system can work just fine as long as everything is in proper order.
Agreed that if your running 27 year old stuff a lot of it is due for replacement.
Hard to suggest a starting point not knowing any history. Check for leaks. Check the bottle and cap. Pressure loss will result in increased temps.
Good news is even a complete cooling system replacement (radiator, hoses, water pump, t-stat, bottle and cap) isn't too terrible of a project. Even if you include the fan clutch.
Check for leaks, coolant smell and bottle expansion then repost.
Old July 26th, 2014, 22:40
Ive just recently replaced the water pump. Next im gonna put a new thermostat in and see if that works. Thanks for the advise
Old July 27th, 2014, 08:44
87manche's Avatar
it can, the problem is keeping it in proper working order.
I prefer to just swap it, then you don't deal with it ever again.
Radiator for a 91 has the threaded port for the renix fan temp sender and is cheaper and much more available than the closed system part.
drops in. Use generic autozone $8 coolant catch tank and you're done. Take you like 2 hours. I've got radiator swaps down to 30 minutes these days. Three this year....
Old July 29th, 2014, 10:37
sidriptide's Avatar
sidriptide sidriptide is offline
nobody of any consequence
how much time are you spending over 3000 RPM ?? the 4.0L can certainly handle it, but it seems like you're winding out the RPM, and hard acceleration or sustained high RPM in lower gears will absolutely show you if your cooling system is not up to the task.
Old July 30th, 2014, 07:35
yossarian19's Avatar
yossarian19 yossarian19 is offline
There are a bunch of things that could be causing this.
Old, clogged radiator
Weak fan clutch
Lower hose collapsing down and restricting flow under suction
Cracked head
stuck / lazy thermostat
etc.
What color is your coolant? Everything clean in there?
When you shut off the engine, does the fan keep moving for a few spins or does it stop pretty quickly?
Have you done any maintenance on the beast? Fresh water pump, etc?
Old July 30th, 2014, 07:40
CompleteCherokee CompleteCherokee is offline
did you replace the water pump due to the overheating? Or did the overheating start after you replaced the pump?
Old July 30th, 2014, 13:02
The belt broke a little and when it did it wrapped around the fan causing the fan to not spin. And the waterpump is new. I replaced it because it was the original and was in pretty bad shape. I drained the cooling system and put new coolant. And it did not over heat before. I dont let it get to where it is actually over heating but it does get up to about 250. Im pretty sure the thermostat is sticking either that or my temp gauge is not working. Because the gauge will say its at about 210 or so and then it will drop down all of the sudden to about 150-170and then back up to 210.
Old July 31st, 2014, 06:00
the dropping down is probably the thermostat opening, and once it drops below the rating for the thermostat, it climbs back up. What is the rating of your thermostat?
Old July 31st, 2014, 12:17
Hypoid's Avatar
Hypoid Hypoid is offline
Sounds like you have an air pocket.
The Lost Boys' motto: We don't know where we are going, but we'll be there for awhile...
Old July 31st, 2014, 13:46
scottmcneal scottmcneal is offline
What he said, need to burp it.
I have a closed system in my 89 and run with the AC on while off roading, does not over heat after i had the system done by a shop. A professional radiator shop does a better job than the crap you get in the parts house.
Today is a cool day, only 110 and i can run all day with the AC on.yes even when it is 120 out.
did you burp the system a few times, and run the heater while burping?
Old August 1st, 2014, 14:29
I havent tried burping it. Ill give that a try
Old August 2nd, 2014, 06:31
cruiser54's Avatar
cruiser54 cruiser54 is offline
REplace the crappy cap on the coolant bottle with a 703-1396 from Napa first chance you get also.
overheating issues joedurt1 OEM Tech Discussion 4 January 8th, 2013 20:34
Overheating Issues cb3725 OEM Tech Discussion 21 February 11th, 2010 01:53
Overheating issues GinisKratos OEM Tech Discussion 37 June 1st, 2009 19:24
Overheating Issues... 5-90 OEM Tech Discussion 26 December 19th, 2006 16:10
overheating issues rngrfrd2000 OEM Tech Discussion 6 February 27th, 2004 10:31
