Old January 7th, 2013, 19:44
joedurt1 joedurt1 is offline
Exclamation overheating issues
Blew out the water pump...Replaced water pump...thermostat and hoses.
Temp will not maintain steady. Sometimes too hot and some times too cold.
Heater blows fine when at at idle but cold when going down the interstate and at times the engine totally overheats. What the heck ?
Old January 7th, 2013, 20:02
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: overheating issues
Year, specs, OEM, MODs... details????
T-stat may be sticking, even new ones. Sounds like the new stat may be bad, but we need the details above.
Is the water pump impeller the correct rotation?
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 7th, 2013, 20:28
MaxxXJ's Avatar
MaxxXJ MaxxXJ is offline
Radiator could be restricted.
Random thought, you didnt get the failsafe thermostat did you? Those will lock wide open when you overheat and that would cause the engine to get hot at idle and cold while driving at freeway speeds.
flush your system, run a water hose into the inlet side with the engine running and let it flow out onto the ground out the outlet hose, that will push out any debris inside your engine restricting flow as well...
Old January 8th, 2013, 11:50
joe_peters joe_peters is offline
What Ecomike said.
If a closed system, did you BURP it?
Old January 8th, 2013, 20:34
MaxxXJ's Avatar
Originally Posted by joe_peters View Post
What Ecomike said.
Burping it is kind of a PITA if your not totally sure what your doing...
Have overheating issues with your XJ? Hyline08 Vendor Advertisements 0 September 18th, 2012 08:13
I've got overheating issues! 89JeepCherokee4x4 Arizona Chapter 18 May 24th, 2011 08:42
Overheating issues GinisKratos OEM Tech Discussion 37 June 1st, 2009 19:24
Overheating Issues... 5-90 OEM Tech Discussion 26 December 19th, 2006 16:10
overheating issues rngrfrd2000 OEM Tech Discussion 6 February 27th, 2004 10:31
