Old October 30th, 2009, 12:30
cb3725 cb3725 is offline
Overheating Issues
Ok, I had a guy help me replace the head gasket on my 1990 Cherokee. We took the head it had it pressure tested and magnafluxed- all good. We finally finished yesterday and it is still overheating. It only idles for about 5-8 minutes before it passes 210 and keeps climbing until I shut it off around 250. No water in the oil or anything.
I've replaced the water pump and the thermostat (which there wasnt a t-stat in there when I opened it up. Previous owner must have removed it) and now have done the head work. What else could it be? I have no radiator cap- it's the pressurized system with the fill tank.
Also, even when it is running, that top hose feels empty, like no coolant is passing through it. Does that sound like my radiator might be bad? Or the heater control valve? Bad water pump?
If it is the radiator, I've seen some on here suggest going to the open system instead of the closed system I have now. How big of a deal it that to change?
Old October 30th, 2009, 14:28
joe_peters joe_peters is offline
Re: Overheating Issues
You probably have air trapped in the system--closed systems are notorious for this.
BEST BET: Remove the thermostat and drill two small holes in the flange, far enough in from the outer edge so that when reinstalled the two holes will not be covered, placing the thermostat so that the holes are located at 12 and 6 o'clock. Fill the system. Park with a nose-down attitude, pull the temp gauge sender at the DS rear of the head, and then add coolant to the pressure bottle until all the air is out of the system. Reinstall the sender and test.
Old October 31st, 2009, 04:52
Trapped air in the system will keep the coolant from flowing? I will give this a try on Tuesday- first chance I have to work on it again!
Thanks
Old November 1st, 2009, 08:25
MJmk's Avatar
MJmk MJmk is offline
Make sure there are no cracks in the coolant tank, and the cap fits on tight. I went through this same problem after replacing the tank and cap, only to find the new cap was bad. Put my old cap on, and all is good! The upper hose should be hot, and hard (pressurized) after a few minutes of running.
Old November 2nd, 2009, 09:42
curtmann curtmann is offline
I put a 1992 thermo housing with a sensor hole on my '90. I used a pipe bushing and pipe plug as a bleeder. works perfectly, cost $25. Just fill your system with the pipe plug out until you have coolant running out of the hole in the pipe bushing, then plug it. Also, drill the holes in the thermostat. No probs after that.
Old November 2nd, 2009, 11:40
RichP's Avatar
RichP RichP is offline
Did you use the correct direction water pump ? Next, how did you set your belt tension ?
Most who set it by hand set it to under 100lbs when it should be 170lbs for a used belt and 190lbs for a new belt.
Old November 2nd, 2009, 11:51
How can I tell if I have the right direction water pump? I dont have the original anymore to compare and just took the one the tech gave me from Advance Auto.
As for the belt, I did put it back on by hand and just tightened up the adjustment bolt until the belt wouldn't rotate more than about a quarter turn if you tried to twist it. I'm really not too sure how that goes in lbs though.
Old November 2nd, 2009, 14:27
RichP's Avatar
Quarter turn, you are around 60-80lbs, I actually have tested this with a krikit II tension gauge when this came up several times before. As for the correct pump, there should be an R either on the housing or on the impeller itself. Or take the part number to advance and pull another one and look.
Bleeding the system too is very important as well as the holes in the thermostat.
Old November 3rd, 2009, 15:53
That was it. Bled the air out today and the temp is back to normal. Thanks!
Old February 10th, 2010, 07:29
Quick follow up question, now that it is all back together and running smooth, there is a big difference in the normal operating temp. I used to run at around 210 all the time. Since November or so, it has never gone above 150-160. Could it be just the winter air is keeping it that much cooler?
It seems like a good thing considering my previous overheating problems, but I know some on here say it is important for efficiency that these engines run hotter.
Old February 10th, 2010, 09:17
winterbeater's Avatar
winterbeater winterbeater is offline
That's no good. And it can't be THAT cold in GA. I wonder if the holes in the thermostat are letting too much coolant by. Do you remember how big you made them?
Old February 10th, 2010, 09:46
Xjcrazy57 Xjcrazy57 is offline
Whats the status on your radiator. i changed the original one that came with my 1989 with a 3 row one from napa. It is night and day. My gauge just sits at 195. And it used to do what yours does.
Old February 10th, 2010, 09:55
Yea, the weather really isnt that cold normally - high 20's this morning but its rare that it gets that cold.... When I put in the thermostat, I didn't even drill the weep holes in it and I have the original radiator. Ha, I guess I now have the complete opposite of my original problem when I started this thread.
Old February 10th, 2010, 09:56
My rad is original. Your original rad used to run cold?
Old February 10th, 2010, 10:58
Crawler's Avatar
Crawler Crawler is offline
Did you put the right thermostat in? Needs to be 195*
Overheating issues GinisKratos OEM Tech Discussion 37 June 1st, 2009 19:24
Overheating Issues... 5-90 OEM Tech Discussion 26 December 19th, 2006 16:10
radiator leak, overheating issues HeightsHoustonXJ OEM Tech Discussion 5 July 12th, 2006 07:35
Heating and overheating issues Mikel OEM Tech Discussion 2 February 23rd, 2006 20:26
overheating issues rngrfrd2000 OEM Tech Discussion 6 February 27th, 2004 10:31
