Old July 24th, 2021, 08:11
cjstefan cjstefan is offline
Amazon winch rope
So I see the XBull winchline says it's sk75 (sk?) Dyneema. Is it good quality or a false sense of security? The strength is rated way higher than the high end ropes. I just got a smoking deal on an arb bumper ($200) and a brand new never used Warn m8000 ($500). I have RE 4.5 coils. I want to save any weight I can (no the ARB doesn't weight much at all despite popular belief) so I'm thinking of switching to this line for my once a year use. In the meantime I'll save up for high end line if I necessary. So anyone use it or test it? Will I even notice the 20 pound weight difference?
Old July 24th, 2021, 09:21
RCP Phx RCP Phx is offline
Re: Amazon winch rope
It's really not worth it unless you are in competition or use it a lot. My winch is almost 15yrs old and the cable still looks brand and un-marred by all the abuse it see's dragging over rocks and other debri!
Old July 24th, 2021, 09:54
I'm not sure how this applies to you, but here in AZ rope catches all the cactus permanently and it sucks when your feeding it back on the drum!
Old July 24th, 2021, 19:32
I'm not so much interested in it for strength purposes. It's 99% for the weight savings. My question is, how can Warn and Masterpull and those guys charge $300 to $400 and this XBull is $80 or $90 if it's sk75 dyneema like they say
Old July 25th, 2021, 17:35
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
Branding?
97í XJ lift lockers 35s mid arms 9"/hp30 trussed warn hubs wj brakes 1ton OTK 4.56s etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old July 25th, 2021, 18:48
Groot99 Groot99 is offline
Still havenít pulled the trigger on rope yet. But reading this since Iím moving to az. Maybe Iíll keep my steel line.
Old July 25th, 2021, 20:52
VAhasnoWAVES VAhasnoWAVES is offline
Wow… I had to look up winch rope prices. 5 years ago a smittybilt rope was $100. My recommendation is always going to be rope over cable. Far easier to work with, lighter, and safer under tension. That said, I would gamble on off brand dyneema. Thought I would not want a cheap hook on it.
Old July 28th, 2021, 18:34
I think I decided I'm going with TRE rope. Everyone says it's great and it's only like $150 for 85 feet of 3/8. Granted that's double what the Amazon stuff costs but half of what the big name brands charge. I planned on going with a factory 55 for the hook or whatever it's called, but then I saw their prices
Any recommendations or should I just stick with my Warn hook?
Old July 28th, 2021, 18:40
denverd1 denverd1 is offline
gotta change your fairlead. and whatever on F55
Old July 28th, 2021, 19:00
creating a secure link between you and your anchor is really important. I do not use F55 stuff... I use 3/4 inch shackles, straps and my winch line to create a secure pull.
Old July 29th, 2021, 19:44
I'm going to get a new roller fairlead since I'm running the ARB and it has that roller fairlead support built in to it.
Old July 30th, 2021, 07:21
if you're running a synthetic line (not wire rope) you need a different fairlead. not a roller.
Old August 3rd, 2021, 19:59
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
I have seen (but can't remember where) a set of poly fairlead rollers for use with synthetic rope, but they're not too common and there's still the chance of it getting pinched in the corners.
The "standard" for synthetic line is the hawse fairlead.. They have the same "bolt pattern" as the roller units, and I'd frankly be shocked that you couldn't put one on that ARB bumper.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old August 10th, 2021, 04:06
A roller fairleads fine as long as its brand new with zero scuffs.
Winch w/Syn. Rope Serious Offroad Vendor's Specials 0 January 31st, 2016 08:51
Some help with Winch Rope. collkid Colorado Chapter 21 March 7th, 2011 08:24
Winch w/ plasma rope EnderUSAF Arizona For Sale/Wanted 4 October 24th, 2008 15:00
winch rope ?'s trailbound xj Modified Tech Discussion 7 October 20th, 2007 15:09
Winch Rope jonboy Modified Tech Discussion 11 May 22nd, 2006 20:10
