Old July 21st, 2018, 13:08
Kestrada5's Avatar
Kestrada5 Kestrada5 is offline
Dana 30 vacuum disconnect question
Hey so I have a 97 xj with a HP Dana 30 upfront and I believe it has a shitty pinion bearing...considering the horrible noises it makes. Anyways I went and got a Dana 30 from under a Comanchee yesterday but it has the factory vacuum disconnect. I was wondering if I could entirely switch the carrier and pinion(including the shim stacks)from the comanchee axel and just swap it into my existing axel under my jeep. Ive heard from a couple buddies that it wouldn’t work and the housings are a little bit different, or some other issues. Some said it would work because they’re the same. I’m asking for a more professional answer rather than hearsay. Thank you.
Old July 21st, 2018, 13:19
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Dana 30 vacuum disconnect question
Differential internals are not Plug and Play, at the minimum you would need to use some specialized tools and technical knowledge to check/set the shim thickness and gear engagement pattern.
You can use the 97 axle shafts to delete the vacuum disconnect.
Probably the easiest/simpliest option is to buy a complete non-disconnect axle.
Originally Posted by bimmerjeeper
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old July 21st, 2018, 13:51
mongolchuck mongolchuck is offline
If you're gonna go through all the trouble of trying to swap all internals you should just change your pinion bearing. Even that would be easier than swapping all the other stuff like outer knuckles, brakes and axle shafts.
Welding a Vacuum Disconnect Dana 30 mbogosia Modified Tech Discussion 6 May 12th, 2010 17:04
vacuum disconnect??? mitsumotors OEM Tech Discussion 2 April 26th, 2008 16:28
Dana 30 Disconnect Question ukdkbr OEM Tech Discussion 7 November 28th, 2006 14:54
vacuum disconnect grundan OEM Tech Discussion 8 March 16th, 2006 04:58
Vacuum Disconnect Dana 30 Diff yardape OEM Tech Discussion 6 October 25th, 2005 14:32
