Old July 18th, 2018, 13:32
asymptonic asymptonic is offline
Incorrect Oil Pressure Reading
Continuation of my thread about my new Jasper motor. Just got it back from the shop where they had read a hot idle oil pressure of 20psi with a mechanical gauge, while the dash gauge shows 9psi.
The sender has been replaced, and I finally bought my own mechanical gauge to double check their work (don't particularly like this shop, but they were one of two local shops that would work with Jasper and the other was even less reputable).
Lo and behold, it is indeed 20psi on my gauge. What are my next steps. Wiring near the sender looks new. I'll try and check the wiring to the ECU and dash, but I'm new to electrical. What would you do?
1998 4.0 I6, AX15, NP231
Old July 18th, 2018, 13:41
old_man's Avatar
old_man old_man is offline
Re: Incorrect Oil Pressure Reading
Start by cleaning up all the grounds, mainly the ones on the dipstick mounting bolt first.
Get rid of any Teflon tape on the oil pressure gauge threads.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old July 18th, 2018, 13:42
Interesting, there is some teflon tape on the new gauge. What would be the effect of that beyond the presumably better seal? Ground issue?
Old July 18th, 2018, 13:51
old_man's Avatar
Yes.
Old July 18th, 2018, 13:57
RCP Phx RCP Phx is online now
It can effect the body/core temp readings but grounding is done thru the ECU sensor ground.
Old July 18th, 2018, 21:04
The teflon? I thought the temp sensor was near the fuel rail.
In the same engine replacement I sprung for the max cool mopar radiator. After a ~1500 mile roadtrip which had had trouble in the last, hot, uphill segments on previous trips, temps looked remarkably stable at about 195 by the gauge with no overheats (two minor ones on previous trips). So the temp readings at least feel and seem right.
Old July 20th, 2018, 19:52
Spent yesterday cleaning up the grounds near the dipstick (G101) and the alternator which was the bigger problem (G103). Went from 1.4 ohms from the dipstick to battery to 0.6. But the gauge is still reading low. Will look at the block to firewall ground this weekend, but barring that, what should my next move be?
Old July 20th, 2018, 20:11
Since the sensor is grounded through the ECU, you could check that the ECU itself has good contact with the body. I use electrical grease on all my connections.
Old July 21st, 2018, 07:46
Will do. I also want to check the resistance at the sender and compare it to the resistance at the pin to the ecu connector. BTW, isn't dialectric grease non-conductive? Or is this some other electrical grease?
Old July 21st, 2018, 09:08
Story so far:
Sender Connector to ECU pin: 0.1ohm
ECU ground to battery neg: 0.2ohm
Power on voltage across sender: 5.1v
Still need to figure out how to test the sender ground itself, since its the 2 wire 98 style that grounds through the connection to the oil filter adapter.
Instrument cluster sweep test looks correct.
Nothing looking bad so far. Is there a way to test the sender itself?
Old July 21st, 2018, 11:22
Nope, it needs to be "conductive" grease(anti-ox)!
Old July 21st, 2018, 17:22
lawsoncl lawsoncl is offline
Depends what you're greasing. I wouldn't use conductive grease in a in connector as it can short the pins. The purpose of the grease is to keep the air off the metal so it doesn't oxidize.
Old July 29th, 2018, 09:55
Just for closure, the issue did turn out to be the sender. I suspect that though they *said* they put a genuine Mopar sender in, it wasn't. I ordered my own and the Mopar one uses different thread sealant and has the part number stamped into it. The one from this shop didn't.
New sender accurately reflects the mechanical gauge.
Is 80 (max on gague) a high oil pressure reading for a '96 XJ 4.0? bradleyheathhays OEM Tech Discussion 13 September 14th, 2014 18:06
False low oil pressure reading, need help troubleshooting tnxj OEM Tech Discussion 17 July 4th, 2007 16:11
4.0 Reading Low oil pressure?? The Adam Blaster OEM Tech Discussion 6 June 19th, 2007 14:02
oil pressure guage reading high rehab OEM Tech Discussion 2 June 1st, 2006 16:05
Oil Pressure Gauge Reading High XJDanny OEM Tech Discussion 1 August 25th, 2003 21:09
