Old July 18th, 2018, 11:14
KEEP3R's Avatar
KEEP3R KEEP3R is offline
Unhappy '99 XJ died will coming off highway, won't start
Where to begin, where to begin...
my 1999 Cherokee XJ with 187,000miles has been running great for the past year and I was coming off the highway 2 weeks ago and she died right when i came to the light. I have not been able to start the XJ since. I've checked fuel pressure and checked to see if the injectors are working (both are good).
The XJ turns over very well and sounds like it wants to start, but just doesn't.
Next step was checking spark. I checked the spark and it was yellow-orange colored. I replaced the crankshaft position sensor just as a precautionary repair to see if that was the issue. It did not fix it.
I next replaced the distributor cap and rotor as well as the spark plug wires. After replacing those three things related to spark, i have no spark at all. i double checked by putting a spark plug on the wire coming off the ignition coil, still no spark.
So I checked the input connector on the ignition coil to make sure it was getting power and yes it was getting ~12 volts. I replaced the ignition coil and there is still no spark.
I also cleaned up the ground points on the firewall and dipstick area.
I'm at a loss of what to do next. Any input would be much appreciated! thank you all!
Old July 18th, 2018, 11:58
Cummins90 Cummins90 is offline
Re: '99 XJ died will coming off highway, won't start
Where did you get the new CPS from. Put the original back in and check for spark? What do your plugs look like? Have you hooked up an obd2 scanner and looked at the key on live data?
Old July 18th, 2018, 12:08
KEEP3R's Avatar
I got it from O'reillys, BWD brand. plugs look ok, the P/O replaced them 2 years ago.
I can try putting the OEM CPS back in and checking for spark.
I do not have a obd2 scanner
Old July 18th, 2018, 18:54
I have had a bad CPS out of the box. Before you switch that back how did you test the injectors? Did you pull the rail and point the injector tips up while cranking to see the injectors fire? (Don't smoke while doing this)
Old July 18th, 2018, 20:10
Runnin'OnEmpty's Avatar
Runnin'OnEmpty Runnin'OnEmpty is offline
Sounds like the coil isn't getting a proper signal to fire the coil, and that comes from the ECU. They rarely fail, but that's my guess.
OBD II code readers are cheap, a code would really help for a diagnosis...
Old July 19th, 2018, 15:40
cody4359 cody4359 is offline
I had an issue hunting 2 years ago. Damn thing died and left me 15 miles or so back on a jeep trail. Got it home did all the cheks your doing, turned over great. New crank pos, cap/rotor, ignition coil helped a bit. Then I found the camshaft position sensor under the distributor cap. Went the a junk yard seeing as I could only fund them with the distributor assmebly. Junky yard piece fired it right up. So if your not getting spark after messing with the cap I'd look there
Old July 19th, 2018, 18:17
Wyvern Wyvern is offline
Cody is 100% right if you haven't already check the camshaft position sensor on our XJs. They're actually not so much sensors, they're called pick-up coils and they determine the cam position through inductance.
96 XJ - engine died on highway, cranks, doesn't turn over. fsupaintball OEM Tech Discussion 8 July 26th, 2013 14:16
Jeep Died on the Highway... CPS? kdailey4315 OEM Tech Discussion 16 February 26th, 2012 21:30
'01 Died on the Highway Eliminator89 OEM Tech Discussion 11 June 21st, 2011 12:25
XJ died going down highway. MisterFubar OEM Tech Discussion 10 August 15th, 2007 22:56
Died on highway...wont restart OverlandZJ OEM Tech Discussion 10 April 20th, 2007 10:12
