Old March 5th, 2018, 16:03
RCP Phx RCP Phx is offline
Re: 2000 engine compartment wiring harness
Got her painted looks good but I need to add a clearcoat when I get back. Will do a gun write-up in the autobody section.
Old March 6th, 2018, 09:22
Green Mesa XJ's Avatar
Green Mesa XJ Green Mesa XJ is offline
Which spray gun did you use? Iíve heard the 3M 16580 is a very good, affordable paint gun.
Old March 6th, 2018, 12:34
That's the one, Accuspray!
Old March 6th, 2018, 14:29
I was thinking of an electric sprayer until I heard about that sprayer. Itís got really good reviews from DIY to paint and body shops.
I need to respray two of my Jeeps, tough finding the time or desire to do all the prep work is holding the projects off. When my friend had a spray booth we repainted my first car, incredible amount of work to do it right.
Old March 6th, 2018, 21:52
I talked to the paint store today,.Instead of adding a clear coat (and since I have paint left over), they recommended spraying on a few more coats of color(already have 3 coats) and just doing a "cut and buff" first.
Old March 19th, 2018, 02:30
Well I shot 3 more coats on yesterday and I will start re-installing it all. I will try a "cut/buff" later, I need to get this one running so I can install a shift kit on my original 2k!
Old March 28th, 2018, 11:31
I've got the spare jeep all put back together now. As I prepare to rub out the paint job, I will have to work on the harness for this one. Between my old harness and the Cali one I bought, I will try to make one good harness.
Old March 29th, 2018, 07:28
What it looked like before, and what I've been up doing!
Old April 8th, 2018, 21:30
I haven't gotten a lot done. Tues I received my new 9" buffer machine(apparent my old one was to fast) and Sat I finally received my buffing pads! Waiting till I can start and move it out of the sun before I do and cut/buff.
In the mean time the harness has been a major P.I.T.A., all 3 harnesses have some damage from the area around #5-6. It is done now except I need more split-loom!
Old April 9th, 2018, 07:59
Heavyopp Heavyopp is offline
Damage around 5-6? Please explain
If you found the same damage on 3 different harnesses then it stands to reason that many of us should look there when troubles start
Right now I'm having troubles with code P0432 -- I have new pre-cats -- when scanning the o2sensors I get intermittent readings from sensor 1 bank 2 -- which would coincide with P0432 -- Without looking at it I think the bank 2 sensor 1 wiring comes from that 5-6 injector area in the harness
Thats the 1st place I'll look -- hopefully you just saved me from days of searching for an electrical gremlin -- Thanks
Old April 9th, 2018, 08:32
The common damage is above the cylinder 5+6 area, I've heard a lot a similar comments!
Old April 9th, 2018, 08:59
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Glad to see someone else out there who still knows what a nailboard is and how to do proper harness work.
BTW... I am seeing more and more issues w/ people having broken and shorted wires in the area of cyls 5 and 6 and from there to the firewall as well. Common issues include basically any electrical fault code (stuck high, stuck low, intermittent, lack of function, etc) on anything that runs off that harness:
- injectors
- MAP (on 96+)
- upstream O2(s)
- IAT
- CTS
- TPS
- IACV
- CPS
off the top of my head. Probably others. It's due to the harness flexing every time the motor moves or vibrates, since it jumps from the firewall to the top of the head right there. It most commonly affects injector drive circuits and TPS from what I've seen but can affect any of the listed items. Typically I have people report they are getting a misfire on a cylinder or two, or a circuit failure code, and have already tried replacing the component. When they dig into the harness they find wires broken, chafed, and/or partially broken.
I recommend that people use quality sealant lined heatshrink butt splices (marine grade is great) and splice in a foot or two of replacement wire of the same gauge. Ideally, use the high strand, high temp silicone wire typically used by RC car enthusiasts, it's far more resistant to metal fatigue than the factory wire is.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old April 10th, 2018, 16:41
Out of my 3 harness's, NONE had any degradation anywhere else. All of the damage on all 3 is in the fuel rail section, nothing on the firewall, the starter/oil/dist, coil pack, or the rear trans sensors. All the damage is in the rear half so cumulative heating by the wires is not out of the question, but I have to believe it's mostly exhaust heat.
Kastein......from the start of this thread I wanted to build a new "bulletproof" wiring harness! I found that sourcing all the connectors/terminals to "almost" impossible to find!
Old April 16th, 2018, 21:34
It's Alive !!
Finished the harness Sunday and got it on the road. I took it to emissions early today and everything passed but the CEL. Got home and took the cluster out and sure enough it was a blown bulb. I took it back this evening and it passed so tomorrow I'll go get my title and registration done!
Old July 20th, 2018, 09:43
In post #39 (last pic), that is high-heat fiberglass tape. And in post #44 the pic shows high heat reflective split loom over the regular split loom for more heat separation in that area.
2000 wiring harness LEFTLANESTANG OEM Tech Discussion 3 July 20th, 2016 04:37
Engine Compartment Wiring Harness Question oldbill OEM Tech Discussion 5 September 7th, 2013 10:43
WTB 2000 XJ Engine Wiring harness and/or Complete engine with wiring harness Better_than_Tom SoCal For Sale 28 July 22nd, 2013 18:56
WTB: wiring harness for 2000 XJ altierior InterMountain Chapter For Sale/Wanted 4 August 26th, 2010 13:53
Engine compartment wiring harness SanDiegoXJ OEM Tech Discussion 10 February 7th, 2008 22:08
