Old June 6th, 2009, 20:32
Locked-up-XJ Locked-up-XJ is offline
Slow throttle response
Hi, A friend of mine just bought an 89' cherokee. It ran awesome at first but a couple of days after he bought it it started to stutter when you taped the gas and it also does not down shift when you floor it. We have changed the cap,rotor,wires,plugs, cleaned the IAC, checked for vaccum leaks. When you pull the vaccum line off that goes to the MAP sensor the throttle response is perfect but when you get into the upper RPM's it starts to stutter and miss and has a rough idle, but if you plug it back in it idles perfect but has horrible stutter when you tap the throttle. Anyone have any ideas?
Old June 7th, 2009, 13:54
89 jeep 89 jeep is offline
Re: Slow throttle response
Wow. Thats the same problemo i have. I need to watch this thread.
BTW: My 1st post, hope im welcome. Hello yall
Old June 7th, 2009, 18:29
xcm xcm is offline
adjust your TPS, and make sure your vacuum lines are not clogged.
could also be a plugged fuel filter, or a weak fuel pump
Old June 7th, 2009, 18:38
winterbeater's Avatar
winterbeater winterbeater is offline
RENIX TPS is adjustable. Also can be checked for bad spot with analog voltmeter.
Old June 7th, 2009, 18:44
Of cours, it could be like this: http://www.naxja.org/forum/showthrea...ight=renix+tps
Old June 7th, 2009, 20:33
Thanks, I searched for ever trying to find something. I guess i didnt do it good enough. Ill start testing some stuff and see what i come up with
Old June 8th, 2009, 10:13
Ok, We tested the fuel pressure and wow! It initially went to 38 but then droped to 0 within 20 sec. So...... we will be droping the tank and investigating
Old July 21st, 2018, 11:16
Christopher.g2 Christopher.g2 is offline
Same thing happened with mine. Bought a 400 buck 95 stock XJ. motor mount bolts on passenger side were sheared off in the block, got them out trimmed fenders threw some spacers on the front coils and got everything buttoned up this morning now she's stuttering and falls flat when I blip ty he throttle.
Old July 21st, 2018, 12:03
sinat01's Avatar
sinat01 sinat01 is offline
As dumb as this sounds, run some lucas high mileage fuel system cleaner through it.
My cousin got a 94 and it had a bad hesitation and some of the issues your having, I run that through it and now it runs smooth as glass
Old July 22nd, 2018, 08:09
cruiser54's Avatar
cruiser54 cruiser54 is offline
Go to www.cruiser54.com and complete Tips 1,3,4, and 5 before doing anything else.
Old July 23rd, 2018, 05:42
old_man's Avatar
old_man old_man is offline
Have you removed the TPS? If so make sure you got it back on correctly. The little lever has to be on the right side of the shaft. If not, the butterfly shaft will not rotate the TPS.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Slow slow NAXJA forum SnagglePuss User Support, Questions and Suggestions 4 January 27th, 2008 22:11
improving throttle response alek Modified Tech Discussion 7 July 31st, 2007 14:14
poor throttle response bigin1978 OEM Tech Discussion 4 February 17th, 2006 19:08
HARRRRD Start, skrewy throttle response 1FASTXJ OEM Tech Discussion 2 August 23rd, 2005 21:29
throttle response/hi speed dog izzi mike OEM Tech Discussion 3 August 20th, 2004 20:08
