Stopping the water in my pass. side floorboard
dspilot
Hickory Flat, MS
Whenever I run the A/C, my pax side floorboard gets filled with water. It is coming from (I guess) the evaporater under the dash?? Anyway, how do I stop this. I am guessing that there is a plugged drain, or a hose disconnected somewhere. I have searched for anything obvious, and found nothing. Has anyone else dealt with this? Any suggestions?:dunno:
Thanks
Its a 96 with the 4.0.
At least on my 89, there's a drain hose with a flat end on it that makes a 90° bend on the passengers side, coming from the area with the blower motor. Look for a black rubber tube about 1/2" in diameter with a 90* bend pointing down. The tip may be suck closed.
