stripped fill plug in tfer case
GoBlue
Southern MN
so what do I do about a stripped bolt for the fill plug of my transfer case. I dont know how to fill this thing up exactly now. Oops.
A little more info as there are two types of plugs, Did you strip/round out the 10mm allen socket in the later model cases .
Or the threads in the case ,with the big bolt type head plug ??
Wayne
ASSuming it's the hex head thats stripped... go get a pair of vice grips with the sharp teeth, and get it to bite real tight, then hit the vice grips with a mallet.
ive gotten to the point where i dont bother with open end wrench's anymore, whoever thought aluminum plugs for transfer cases/transmissions was a good idea should be shot.
dont bother replacing it, just dont torque it down so tight. it's just a drain/fill plug. =)
