Old April 14th, 2018, 19:55
alloriginaltone alloriginaltone is offline
Installing axle and new control arms
Here's what I learned today installing the lower control arms and upper control arms and mounting the axle.
It's way way way easier to install the arms on the frame side and then work the axle into place rather than installing on the axle first. I had tried to install on the axle and then mount to the frame...but it proved very difficult even with ratchet straps and jacks. As soon as I "gave up" and removed the axle side, installed the frame side and went back to the axle side it was very quick and easy.
There are a few reasons I can see to install the frame side of the control arms first (especially if you've purchased new arms):
1. The holes on the frame side are pretty hard to see if you're working from jacks on the ground.
2. It's really hard to line everything up if you're wrestling the arms into the fixed non-movable frame. Much easier to move the axle around to fit the holes.
3. Things tend to be in the way as you are connecting it all up if you start with the axle. LCAs bumping into jack stands and stuff like that.
So, with that experience in the books, I can't recommend the axle-first method. I would go with the frame first method in the future.
questions about installing adjustable control arms and upgrading steering blazinjames Modified Tech Discussion 2 June 6th, 2011 07:34
Upper Control Arms, axle bushings. MrShaft696 OEM Tech Discussion 8 August 9th, 2010 06:36
Question about installing adj control arms. hiimmred Sierra Chapter 4 May 21st, 2009 16:35
School me on installing control arms - condoor Modified Tech Discussion 13 July 30th, 2008 19:14
Problems installing lower control arms K2fender Modified Tech Discussion 9 December 25th, 2005 12:49
