OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
clicking noise help ...on heat to a/c.
Ive tried searching but to no avail....my heater / ac is making a v licking noise when changed from heat to cool on the dail just as ut hits the blue line clicking starts.....sny thoughts or help im new to jeeps.. thanks in advance I have a 2001 60th anniversary edition graysilver. 201,000 odometer. Runs great heats great but ....clicking is stoppi g me from.checkinh a/c ....HELP PLEASE
#2
Re: clicking noise help ...on heat to a/c.
Anyone could this be a blend door problem and how can I fix it myself ?
#3
It's probably the blend door actuator. First stop will be to the parts store for a Chilton repair manual. Don't bother with Haynes manuals, they're junk. I've never had to do one on an XJ, but I don't remember them being that hard to get at.
#4
The clicking you are hearing is likely the A/C clutch engaging then disengaging prematurely due to low refrigerant charge.
Open the hood, put it in "click" mode and watch / listen to the A/C clutch. Normal operation is for it to engage and remain until the pressure reaches a low point prior to the evaporator beginning to freeze, then it disengages, the pressure and evap temp rise, the clutch engages again and the cycle repeats............ The A/C temp is regulated by a pressure switch and not through a thermostat or thermistor control. |
#5
Thanks ill do that.
Thread Tools | |
Display Modes | |
clicking noise | jamesbtaylorjt | Modified Tech Discussion | 1 | October 15th, 2011 20:44 |
Clicking Noise | 2001XJ-32 | Modified Tech Discussion | 9 | July 16th, 2009 14:45 |
Clicking noise | jk333 | OEM Tech Discussion | 2 | July 25th, 2008 02:47 |
Clicking Noise | triple 4 | Modified Tech Discussion | 2 | July 19th, 2005 21:14 |
clicking noise!!! | 93Jeepin | Modified Tech Discussion | 2 | August 26th, 2004 18:19 |
