Old March 6th, 2018, 10:34
TDoggs's Avatar
TDoggs TDoggs is offline
Getting ready to change universals
I figure I might as well reset everything in the front end.
I do have a question though. In slow sweeping turns. To the right at highway speeds, I can feel the old wobble trying to start.
As soon as I straighten out, it stops. Since the ball joints were only replaced on one side, could hat be the problem?
Old March 6th, 2018, 11:22
mfascuba mfascuba is offline
Re: Getting ready to change universals
I've found that when I get a new XJ it's worth it to change all universals, ball joints, control arms, steering tie rod ends and the track bar. It's a bit of cash up front, but once you've got it all apart it goes pretty easily. Last one I went over had 92K on it, I drove it without issues to 220K.
Old March 6th, 2018, 14:39
TDoggs's Avatar
Agreed! And Iím probably already 3/4 of the way there!
Old April 15th, 2018, 03:09
TDoggs's Avatar
I want to remove the 4wd drive shaft and drive the Jeep to see if that's what's causing the "rumble" I feel on the highway (it goes away when I engage the 4wd)
Is it safe to do so?
Old April 15th, 2018, 07:41
jeep ride's Avatar
jeep ride jeep ride is offline
If you remove front driveshaft do not engage 4wd you can remove rear driveshaft and drive it in 4wd
Old April 15th, 2018, 08:16
RCP Phx RCP Phx is online now
It's done all the time!
Old April 15th, 2018, 08:48
TDoggs's Avatar
Thanks fellas! Out to the garage I go!
Getting ready to change out a cracked 0331 md21722 OEM Tech Discussion 35 May 26th, 2014 16:16
Getting Ready to Change Exhaust javajeep OEM Tech Discussion 4 January 14th, 2008 17:29
Stronger universals for stock front axle wyndzer Modified Tech Discussion 4 June 23rd, 2004 16:30
need help with universals younggun96 Modified Tech Discussion 16 May 15th, 2004 11:42
To change or not to change - AW4 fluid KLXJ OEM Tech Discussion 3 August 7th, 2003 23:33
