Old January 28th, 2009, 18:31
sharq sharq is offline
my brakes still suck
'93 sport 4.0 aw4 np231 8.25 6.5"lift 33's
i got around to replacing the brake shoes on the 8.25 today in hope that it would fix my
spongy feeling brakes. it did not.
a little history. i traded a hand gun for this jeep about a year ago. it had quite a bit of front end damage. i thought that the unibody might have been tweaked and figured if nothing else i could use it as parts. at best i could rebuild it and wheel it. well, ive rebuilt it and have been driving it everyday now since finally fixing the DW a few weeks ago.
the brakes are weak. the pedal has had alot of travel. i thought i might just need to bleed the brakes. i did so when i upgraded to the longer chevy brake lines last week. i bled them till the fluid came out with no sputtering.
the pads have plenty of material left. new shoes today and hardware kit.
i noticed that the calipers have a very tiny amount of play. i thought that the 2 bolts might not be tight all the way and i ended up braking a bolt trying to make the calipers feel like the were tight all the way like on my '95.
when i brake hard i hear a repeated knocking sound comming from the passenger rear area. no carpet so i hear it clearly. the knocking frequency reduces with speed.
what am i missing here?
Old January 28th, 2009, 18:36
JeepCherokeeGuy99's Avatar
JeepCherokeeGuy99 JeepCherokeeGuy99 is offline
Re: my brakes still suck
replace brake master clyinder. if that still does not work your booster may have gone.
Old January 28th, 2009, 18:39
also verify that you do not have a leak in any of your lines. did you replace with hose line or steel braided?
Old January 28th, 2009, 18:45
the resivour(sp?) isnt losing any fluid. so i dont think theres a leak.
they were stock lines off a chevy truck because they are longer. its a common swap.
Old January 28th, 2009, 18:51
colby44's Avatar
colby44 colby44 is offline
you try and purdge your brake lines to get rid of any air bubbles?
Old January 28th, 2009, 18:55
im saying check for a leak for air getting in. It's possible that air is getting in without you noticing a leak. If your brake master cylinder has never been changed i would do that first. i have an extra one that you can have for free. If that does not fix it then its gotta be the booster. one way i believe you can test to see if its the booster is, while driving, rev up while braking at the same time. if the pedal gets stiffer then its the booster. if the pedal still drops to the floor then its the master cylinder.
i thought thats what i was doing when i bled them. how much fluid do i need to pass through the lines before i am sure i am free of air bubbles?
Old January 28th, 2009, 18:56
joe_peters joe_peters is offline
Power booster functioning as intended?
Fluid bleeding by MC piston?
Long chevy brake lines--would HP/reinforced lines be better?
Old January 28th, 2009, 18:57
i will try that method. driving when i am unsure of the brakes sucks.
Old January 28th, 2009, 19:01
just until the bubbles stop. keep in mind to make sure your resevoir isnt going dry cuz youll be repeating this process for days lol. I know what you mean about the unsureness of the brakes, i had this same prob and i drove down the cuesta grade with it! scarrrryyyy. If it's sketchy, be sure to downshift and dont be afraid to use your parking brake.
Old January 28th, 2009, 19:02
take it to wal-mart at 2 in the morning lol. no traffic and wide open spaces :P
Old January 28th, 2009, 19:04
also, you know the vacuum line going from the booster to the manifold? make sure theres no like in that hose.
Old January 28th, 2009, 19:06
the parking brake dont work too well either. cant downshift, automatic. i keep my distance from other cars and give myself time to brake.
Old January 28th, 2009, 19:07
oh ya and just to make sure you are bleeding in the correct order. back right, back left, front right, front left
Old January 28th, 2009, 19:10
you can downshift in the auto. I do it all the time. if your going 25 below it shifts to first. over 25 your in second etc. just take it easy and dont get hurt. I dont feel like seeing your name on the In Memorium forum!
Why do Drum Brakes Suck ??? Pharaoh XJ OEM Tech Discussion 26 October 11th, 2007 07:20
No Brakes = Suck MongoXJ SoCal Chapter 2 April 3rd, 2007 14:08
my brakes suck please need guidance rowicki OEM Tech Discussion 3 November 29th, 2006 16:49
my brakes suck jimmy forbes Modified Tech Discussion 22 March 19th, 2004 09:26
