Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 84 votes, 5.00 average. Display Modes
  #16651
Old June 14th, 2019, 11:46
PacificEd's Avatar
PacificEd PacificEd is offline
Re: Weekend is over...what did you get done?
I'm glad to see you found another XJ. Your setup and upgrading to long arms will be nice.
Former SEC Chapter President: 2009-2012
Former National Recorder: 2013-2016
Old June 14th, 2019, 12:01
043500 043500 is offline
So a stock XJ can still wheel at the Crawl...
1987 MJ renix 4.0/AW4, D300, 60/14B welded 5.13's and 37's.
1993 XJ 2 dr, 5" lift and 32's
2003 dodge ram 3500 cummins
Old June 14th, 2019, 13:31
Cottontail's Avatar
Cottontail Cottontail is offline
Three-De Off-Road
It sure can - if the owner isn't in Texas during the Crawl...
Dirk DeYoung--Member #176
You'll never leave Harlan alive.
1996 ZJ (200GRND)...2001 XJ (TRALRIG)...2006 XK (TOW RIG)
Old June 15th, 2019, 14:29
Cottontail's Avatar
Three-De Off-Road
Spent some time on the new XJ today. Did an oil change and learned that the engine only has 5 PSI of oil pressure.
Not sure what to do about that just yet. My mechanic said to throw the engine from the other Jeep in it - but that's a little more than my apartment complex will allow in the parking lot.
Considering pulling the oil pan and seeing if the oil tube pick up is just covered in gunk that's not allowing good oil flow. The Jeep did sit for 8 months before I picked it up.
Old June 15th, 2019, 17:05
Drastik Drastik is offline
I feel your pain with the apt. issue.
So far nobody has said anything about my impromptu Jeep restoration projects.
But I know I'm pushing my luck a bit, and there are certain projects I won't attempt.
Old June 17th, 2019, 03:40
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
You checked that with a mechanical gauge or the dash?
1. They're notorious for bad gauges.
2. 5psi at idle is very close to OEM spec and fine. I'd run it until it didn't anymore if it's no knocking.
Old June 17th, 2019, 06:51
bosco01xj's Avatar
bosco01xj bosco01xj is offline
Nice... also your Commander gets 12 mpg? That's a hemi right? We are thinking of snagging a 3.7 V6. Do the V6 Commanders have the engine problems or was it the Hemis?
Old June 17th, 2019, 06:53
bosco01xj's Avatar
My 97 shows pretty low at idle, probably around 5. I've never worried about it.
Old June 17th, 2019, 07:05
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
From what I have read and heard all the mopars have issues if not properly maintained. Hell that applies to everything now days really.
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old June 17th, 2019, 07:27
bosco01xj's Avatar
This is true. We're looking at it tonight and may end up coming home with it.
Old June 17th, 2019, 07:44
Lowrange2's Avatar
Member# 2368
OMG, Commanders are terrible terrible. Save yourself the headache and don't buy one. I can list 6 people off the top of my head who are previous or current owners who will steer you FAR away. Any Chrysler engine that ends in .7 is J-U-N-K.
Old June 17th, 2019, 08:14
bosco01xj's Avatar
This is good information. I know Dirk has had problems with his also.
Old June 17th, 2019, 08:16
bosco01xj's Avatar
Curious what the main problems are with these.
Old June 17th, 2019, 08:34
Lowrange2's Avatar
Member# 2368
1. You get better mileage walking.
2. They drop valves.
3. They break timing chains.
Those are the things I'm aware of, you can ask Dirk, Dan, Kris, my brother in law, my Neighbor and 2 guys I work with.
I'm sure they're hit or miss like every other vehicle known to man but I do know that replacement engines are HIGH.
Same goes for Libertys, Grands and all the other .7 engine Jeeps.
Old June 17th, 2019, 08:46
Ghost's Avatar
Member Number 257
There is actually a class action law suit about one of the motors. Something about sand from casting clogging the cooling system. I was also told by a friend local mechanic that the v-6 in the wrangler likes to eat cam's or cam bearings. From what I've read the drop valve with the 5.7 hemi has been solved or there is a fix on the newer ones. That is what I have found researching. But all hearsay.
Rate This Thread:
What I did this weekend Starscream Modified Tech Discussion 27 January 6th, 2008 21:28
Took the weekend off.... jpbxj79 Colorado Chapter 3 July 24th, 2007 21:15
2nd Annual NAC Mohawk Madness Weekend Sept 3-5th labor day weekend sidriptide North Atlantic Chapter 77 September 19th, 2005 19:48
anybody going anywhere this weekend? MMIXJ Colorado Chapter 5 September 10th, 2004 14:19
