Old January 2nd, 2018, 13:52
Mikep_86441 Mikep_86441 is offline
Re: Going Through a Beater XJ 4.0.
While I was down there installing a new rear main seal on the '88 4.0, I put back the torque converter bolt that was backed out about 1 turn, and torqued it to 28 ft-lbs. Rotated the engine to check the others. All 3 of the other torque converter bolts were 1/2 turn loose !!! That may explain why the knocking went from mild to severe instantly as we drove it home weeks ago. Appears to me that torque converter bolt torque should be a maintenance item.
One piston installed, 5 more to go.
Happy 2018 !!
Old January 5th, 2018, 18:06
Re: Going Through a Beater XJ 4.0. Pistons are in !!
Just got the other 5 piston/rod assemblies put back in with new tri-metal rod bearings. That should raise the oil pressure a little bit. The mains were .001 undersized and looked good so I left them. Put in a new Felpro rear main seal too. No teflon buttons since the pistons were in excellent condition.
How to get the old hard as a rock oil pan gasket off of the block is going to be a challenge.
After the bottom end it done, then it's time to do the 3 angle valve job on the head. I've decided it will be a lot easier to install the intake and exhaust manifolds onto the head, before bolting all of it to the block.
Once this 4.0 is assembled, I'll pull the distributor to spin the oil pump with a drill, to prime the motor.
Old January 6th, 2018, 12:45
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Torque converter bolts just need to be properly torqued and the threads on both sides clean first. Swapped my AW4 10 years ago, have not touched the bolts since then. But if I recall the problem is keeping the crank from turning while torquing the bolts? Two many job with one tool on the harmonic balancer bolt? IIRC
I agree with Lawsoncl, sounds like it was your real problem. But loose bolts and cracked plates are usually very noisy and easy to figure out.
Is the flex plate cracked?????
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old January 7th, 2018, 17:20
No flex plate cracks.
The bolts stayed tight for something like 25+ years. As I tightened them it rotated the crank until the socket was up against the other half of the inspection cover where the starter goes. So they were easy to tighten.
With 4 torque converter bolts, they were definitely the problem.
At least I get new rod bearings and a 3 angle valve job out of the deal.
Old January 7th, 2018, 17:21
Never have I run into a oil pan gasket that just won't die !! An hour and a half got me all of 2 inches cleared off of the pan, and squat cleaned off the block. My 1000 degree heat gun is the only reason I got anything off of the pan. Tried razor blade scrapers, air chisel, putty knives and hammer, knotted wire brush in a drill. Insane !! So I bailed to go watch playoff games !!!
Old January 14th, 2018, 21:42
Re: Going Through a Beater XJ 4.0. Valve Job started !!
Got started on the 3 angle valve job !
https://youtu.be/qFMlkEe9Bus
Old January 15th, 2018, 10:53
Ecomike's Avatar
NAXJA# 2091
Aircraft paint stripper, pre-soak might have helped a whole lot.
Old January 15th, 2018, 11:02
Ecomike's Avatar
NAXJA# 2091
They did not use plastic tanks until much later. 89 and older had OEM brass tanks.
For certain! Didn't help unfortunately.
Today I got about 60% through rodding out the radiator. At least 10% of the tubes were plugged, so far. I think it's the original 1988 radiator as it's all brass with plastic tanks. The bottom 1.5 inches of the center section was covered in debris that might block some air flow. I'll put in a new thermostat too since it's far easier to do with the radiator out of the vehicle. Probably should inspect the water pump too.
Old January 17th, 2018, 16:30
Started on the intake valves and seats in the 4.0 head. The valve grinder was giving me .0035 total valve run out. Spec is .0015. So I pushed the valve deeper into the chuck and the last 2 intake valves are now between .00075 and .0015. That's good. Sure is splitting hairs ! But worth it !! The intake seats are getting .050" seat width. The exhausts will get .060" seat width. Both will make contact on the top 1/3 of the valve face. Even thinking of back cutting the valves a little for better flow at low valve lift. I'm a big fan of getting as much torque at the lowest possible rpm.
Old January 20th, 2018, 19:17
Re: Going Through a Beater XJ 4.0. Update.
Got the valve run out a bit tighter at .00025 to .0015 inches.
Got the oil pan gasket remnants off, but not the block/pan surface, yet.
https://youtu.be/-DUiWG5t4lg
Old January 25th, 2018, 14:48
Re: Going Through a Beater XJ 4.0. The New Thermostat Housing is Warped !!
Once in a while I'm reminded that a new part is not always a good part !!
https://youtu.be/NZG_zQH_kVk
Old January 27th, 2018, 19:25
Re: Going Through a Beater XJ 4.0. Cylinder head done !!
The progress today made me one happy camper !!
https://youtu.be/On1-y1hYSXo
Old January 27th, 2018, 19:32
Re: Going Through a Beater XJ 4.0. Pan Gasket Finally Gone !!!
Man what freakin' pain to get this pan gasket material off of the block !!!
https://youtu.be/HgV9dlRw7bY
Old January 28th, 2018, 08:35
Ecomike's Avatar
NAXJA# 2091
That flat file is the only tool I would ever use, short of a machine shop... It is slow as hell, but that is good, as it limits over removal of metal, and shows you with each stroke where the high spots are!!!!
A strong word of warning, number one, I would bolt the Exh manifold to the head, before welding those cracks, as not doing so guarantees warping the manifold!!! Even then it may already be warped.
I have found that file to be an awesome (slow as hell) but awesome tool for getting the Exh manifold faces flat and parallel, but even then, I had to add a copper silicone covered, copper shim on top on the gasket to deal with a huge warped gap between the inner two tubes and the head on mine. Did that in 2007 and it never once leaked or cracked.
8Mud has also done this years ago, he coached me. Lastly do not remove too much metal on the faces as the bolts over lap the intake and exhaust manifolds and if you remove too much metal to get it flat and parallel the bolts loose tension on the manifold spot you sanded down!!!!
Old January 29th, 2018, 18:08
Re: Going Through a Beater XJ 4.0. Ugly and Warp Free
https://youtu.be/SI6Fxu3-Jng
beater! ehall North Atlantic Chapter 728 July 5th, 2020 07:24
Beater XJ itrack Modified Tech Discussion 7 April 1st, 2011 09:02
Who's got a Beater Rig? Letterman Sierra Chapter 10 November 6th, 2010 11:52
My new beater hollywood32 SoCal Chapter 11 March 9th, 2007 17:34
beater? skunkman Tow Rigs and Trailers 2 October 10th, 2003 07:26
