Prev Previous Post   Next Post Next
Old June 3rd, 2016, 18:42
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Shifter interchangeability early/late?
So I was doing a search and didn't find much on this matter just the bezel and other tidbits.
But can you direct swap a late model aw4 shift lever that is inside over to a early model? With my 91' I'm seeing how the straight shift lever can cause my knuckle to hit the center console but in my 97' the shift lever is curved and a bit easier to use. If it isn't direct swap what would be needed to swap it over? Might as well fill my curiosity if I ever chooses to swap it.
AW4 swap early to late spctrbytz OEM Tech Discussion 17 January 26th, 2018 20:43
early rear flare on late XJ? N8N_99xj Modified Tech Discussion 5 August 19th, 2012 13:04
Late dash into early XJ...I did search. XJRocket Modified Tech Discussion 1 January 3rd, 2009 07:50
wnated early 90's late 80's xj rwallace Wanted: Private Party Only 1 January 7th, 2007 16:34
Late/Early model bumpers karstic OEM Tech Discussion 3 May 15th, 2005 13:48
