I started up the XJ thismorning and heard a vacuum leak, it was the MAP sensor tube right at the throttle body so I pkugged it back in, then I went for about a 25 mile drive and a couple of times going down hills I put it in neutral(to save gas of course) and the engine would die, it did this like six times and it's never done it before, even when I was running with the MAP sensor tube not plugged in.
What could my problem be? Last night I had the hood up and I was doing some wiring for my light-bar so if I did end up unplugging something where should I look first?
This is a 90 XJ, Renix 4.0, AX-15 and 190K miles
Thanks in advance
Thanks in advance
