Old November 3rd, 2019, 11:41
Jeepmedic46's Avatar
Jeepmedic46 Jeepmedic46 is offline
Jeep is a wiring nightmare.
My 2000 Cherokee sport has decided it wants to be a wiring nightmare. Door locks now run the rear windshield wiper. Doesnít do the locks. Other buttons not working or are turning other things on.
Old November 3rd, 2019, 14:03
Ralph77 Ralph77 is offline
Re: Jeep is a wiring nightmare.
First thing you need to do is check all the grounds.
Don't just look at them. Take them apart and clean them up.
https://www.cherokeeforum.com/f2/gre...e-6558/index4/
Start and Post #49.
Ignore the coil. You still have grounds there.
Might help. Definitely will not hurt.
Old November 3rd, 2019, 15:47
Thank you for that link. Iíll clean up my grounds.
Old November 3rd, 2019, 15:49
Heavyopp Heavyopp is offline
I hope this isnít the Jeep you where talking about in your other thread
At least I hope you didnít pay what they where asking...
Definitely have to start at the grounds but from there check the driver side door ó pull off the drivers kick panel and check all the wires where they enter the rubber boot between door and door frame
Most likely youíll find wires in need of repair
Old November 3rd, 2019, 16:06
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Failure of the drivers door and the tailgate wire harness is very common. Since the door lock are always 12 volts positive hot, any short circuits to ground, or to other wire circuits can most certainly cause odd behaviors. As already suggested, start with a physical and visual inspection of the driver door and tailgate wires inside the rubber boot at the hinges.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old November 3rd, 2019, 20:56
Fortunately I didn’t pay the asking price. They had said there were issues with directional after the engine swap. The cigarette lighter just pops out and the lights on the switches next to it come on. Wasn’t able to do much with the Jeep today. Will look at it in more depth tomorrow. Could the wiring get messed up after the engine swap? I expected issues on a 20 yr old vehicle. Electrical isn’t my strong suite.
Old November 3rd, 2019, 21:24
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
First thing, buy a copy of the 2000 XJ Factory Service Manual, the real thing.
Section 8W has the schematics for your year and, maybe more importantly, it shows the locations of plugs, splices and grounds. It's invaluable when tracking down electrical problems.
Both of my XJ have had ground problems, it isn't uncommon, Chrysler didn't spend much on corrosion proofing.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old November 4th, 2019, 01:00
Sent you a PM.
Old November 4th, 2019, 06:58
old_man's Avatar
old_man old_man is offline
Start and Post #49.
x2
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Death Wobble + Knocking Noises... a Jeep nightmare. HeyAwesomePeople OEM Tech Discussion 13 December 15th, 2019 12:22
Anyone near Spring, Tx that knows Jeep wiring? Sixshooter1125 Red River Chapter 6 November 22nd, 2008 05:44
Wiring nightmare!!! Georgia Mike Modified Tech Discussion 1 August 16th, 2007 14:09
Jeep Owner's worst nightmare Ecarlcl OEM Tech Discussion 7 November 10th, 2003 14:54
Dash Wiring Nightmare madman23 OEM Tech Discussion 7 November 6th, 2003 11:52
